Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- EcoBoost Pros and Cons
Important information to help you understand your Ford truck
5.0 or 3.5 Ecoboost mpg's
#76
My last 8 cylinder 2007 Ford F1504x4 got great 18-20 mpg over 125,000 miles, My new 2012 F150 king Ranch ECo boost 4x4 had 21 mpg on the door sticker so i opted for the fuel milage over the Superduty, sadly with 25,000 miles it gets 17pg hwy and 5 mpg hwy in the winter.
Welcome to FTE!
I would need more of an indepth comparison to be able to respond to your post. Example, which engine and axle ratio did your '07 have? Which axle ratio does your KR have?
The 21 mpg highway for a 4x4 ecoboost is the EPA estimate for my truck. The truck in my signature is an XLT Scab 4x4 with 3.31 axles. My truck is lighter than yours and does not h ave an aggressive pulling gear but more of a highway gear. I am surpassing the EPA estimates in city and hwy driving.
#77
There is no cheating physics. You apparently missed the class in heat transfer using the mass float rate portion of the equation. You can increase the mass flow rate to increase the heat transfer when you have a reduced contact or resonance time. Im not going to derive the equations on a forum board. But the physics works out fine. I promise.
There has been no documented overheating failures on the ecoboost to date, and i doubt there be. Cooling is probably one the least interesting topics when considering the ecoboost. The bottom end on the other hand is very interesting. 6 bolt mains and built like a diesel. no wonder these engines have has had so little mechanical issues.
No doubt Ford has done its homework on this so I hope for the best. When it's proven I might even change my mind about owning one.
#78
I love the concept
#79
#80
My Wifes' '09 Platinum could really feel the altitude at our Arizona retirement house which is at 5800 feet elevation. It was normally pretty peppy when in Houston which is basically sea level.
We replaced it with an '11 Ecoboost Platinum and the difference in high altitude performance is profound. Little to no degradation in performance in the mountains. The only caveat is that regular fuel at those altitudes is only 86 octane and the EB has to have 87 or better so you have to run middle grade gas. But other than that the new EB truck flat runs better than the old 5.4 while there.
Now the question of whether or not the 5.0 would suffer a performance hit will have to be answered by someone who has driven one in both places. But for us and what we are doing the Ecoboost is the better engine to have.
Now if Ford could just give it that 5.0 rumble......
#83
2012 fx2 screw with the 3.55 gears and I'm getting 17 city and around 21 highway when I cruise. But I haven't gone a whole tank without getting on it to get around slow drivers or to make hemi drivers feel bad Lol. I know mine is set up best for fuel economy, but I didn't buy my truck to save money on gas. I bet the difference between the 2 is minimal, where the bigger difference is would be the performance towing and hauling. Anyway my main point is there is more to owning a vehicle than swinging the payments and if a mpg or 2 is gonna sway you maybe your shopping in the wrong isle
#85
2011 scab Ecoboost, 4x4 offroad package (3.73). Over 40k miles now. 80% highway/20% city. Overall average is 16.4mpg. That's 3 mpg better than the 1998 Dodge Dakota 5.2L it replaced but not stellar. My experience has been that the 20 mpg is achievable at 50-55 mph but interstates with the cruise at 72-75 mph takes it right down to 16.
#87
But if you are indeed getting these hand calculated numbers, pm me cause I want whatever you have hooked up to it
Sorry for the hijack guys, however I am interested in a new truck and the 5.0L has been the direction I am looking. But I do want to see what the new vans look like before making the move.
Dean
#88
2011 f150 Platinum 3.5 Eco 3.73 heavy tow package. Best hwy 17-18mpg. 12-13mpg city. 9mpg towing a 23' enclosed snowmobile trailer with about 1,000 lbs in it.
21,000 miles. Maybe a 1mpg boost using premium fuel ( no diff for non ethanol blend). Pulls like my previous diesels but I am done trying to figure out how to bring the mileage up to the window sticker. Trading in this weekend for a new King Ranch Superduty with the 6.7.
#89
