Engine Issues
Engine Issues
Will I have been out of pocket because I have changed job's. I am a lot closer to home how.
I have had some issues with the truck. First my fan came aprt and did some damage to the rad. Put an electric one on and a larger alt. Then I it was using a lot of oil fo a new engine. Found out it was come threw the PCV valve.
Now when I take it up to high RPMS for a few seconds when it comes back down it wants to run rough for a few seconds like may be a weak valve spring or bad lifter. I put new lifters in but did not replace the valve springs.
Can anyone help it is a 351W.
Can you run a compressio test or better yet a leakdown test? You can probably borrow the tools from Autozone or other chain stores. Is this a rollerblock engine or an older 351W? Carb or EFI? Cam? Definitely need more details if you want informed advice.
Weak valve springs will often act like a rev limiter at high rpms. Those symptoms not likely a lifter unless perhaps there is debris causing it to stick when fully pumped. Stock style oil pump wiith normal oil pressure right?
steady vacuum is certainly a good sign internals are likely good. If you had a bad spring vac would flutter at higher rpms. Wonder if perhaps the carb is having a problem with fuel level control coming off higher rpm? Any chance it is flooding a bit when the problem occurs? Just a wild guess of course since I can't observe it. What carb and fuel pump you running?
MavSprint
02-23-2014 12:34 PM
crazy-redneck79
13
03-09-2010 08:42 PM
cofecup
45
12-19-2009 07:56 PM
matt16875
28
04-09-2007 11:51 PM
