Cruise control deactivation switch
I have a 1995 motorhome with a Ford Chassis and 460 engine. The cruise control is not working. The horn and brake lights are operational. The recall has been done also. When the engine is on and it is in park the deactivation switch has power on both sides. I cannot find a wiring diagram for this but I would think that the switch should be open unless the brake pedal is depressed. When I depress the pedal nothing changes, still hot on both sides. I have unplugged the switch and test drove it but it still doesn't work. I was hoping it might work since when disconnected the harness is hot on one side and not the other. Does anyone know if the switch is supposed to be hot on both sides when in park? Any suggestions on what to try next?
thanks in advance for any replies!
Thanks for your reply. That diagram is a huge help!
It does sound like my press switch is faulty, but at the same time it doesn't sound like it should prevent it from working, just not turning off. It sounds like I need to find the boo switch and make sure it is working correctly and if so I need to check to make sure the servo isn't locked up. Any other suggestions?
The recall pressure switch must supply power to the speed control servo module or the speed control will not work. Unplugging it will prevent the speed control from working.
By the way almost 90% of the time the only thing wrong with the speed control is dirty brushes on an F53. You need to clean the brushes and it will more than likely work OK.
I take it you do have an F53, if not let us know what you have as my diagram above may be wrong also.
I went through the troubleshooting flow chart from all data and everything checked out until I got to the step where it says to replace the speedometer/odometer program module and retest. It appears that this module is part of the instrument cluster? Has anyone else had a defective cluster cause the cruise to be inop?
Another_mike
05-30-2019 06:17 PM
mvfddw
1999 to 2016 Super Duty
09-26-2011 04:09 AM
1993F150
21
02-08-2004 06:43 PM
