Intro
Look at the door jamb on the drivers side. It'll have a bunch of codes on it, one is gear ratio. It has a Dana 50 Twin Traction Beam front end, and a Sterling 10.25 rear end. The Sterling is very tough. The Dana 50 is often swapped out for a Dana 60 straight axle from an F350. Transfer case is likely a BW1356, but if you crawl under you will be able to find a tag on it somewhere that says what it is. 460s are good motors, expect low fuel mileage. 9-12 MPGish loaded or unloaded.
69Cobra
05-10-2010 01:47 PM
hotroddually
04-27-2009 06:17 PM
gtro8098
09-19-2006 05:06 PM
homer95127
08-28-2006 06:20 AM
