Engine Compartment Fire
No - "It's not rocket science". However IMO there is a major difference between "the cruise control switch" & the 'wet' switch that deactivates cruise control.
Hoped to make it clear that disconnecting "the cruise control switch" at steering column may not have the same effect as disconnecting the 'wet' deactivation switch by master cylinder.
Not sure what "If it's not connected, it has no brake fluid to short it out, weather it has power or not." is?
Note that the TI 'wet' deactivation switches, that are at the center of the Recalls, can apparently short, smoke & ignite fires - w/o ever leaking a drop of brake fluid externally "onto the ground".
The defect is described as a totally hidden internal leak, inside the deactivation switch itself, combined w/it being unfused & always hot.
If "brake fluid was just leaking through the switch onto the ground" it would be immediately obvious & a No Brainer to get it fixed
It shorts out when the switch leaks brake fluid on the circuit. If it's not connected, it has no brake fluid to short it out, weather it has power or not. That's why my mom's van never caught fire, the brake fluid was just leaking through the switch onto the ground while I had the pigtail ziptied off to the side where it won't touch anything.
It's not rocket science. If it's badly leaking and you disconnect it, then clean it off or disconnect it at the source.
The point of my disconnecting my mom's cruise switch is that if it ever starts leaking, which it did, the pigtail won't be connected to start a fire.
The worst that will happen with it connected is it could set your car on fire, burn your house down and possibly kill someone.
All I was saying is that if you disconnect the brake pressure switch on the master cylinder, the one that deactivates the cruise control, it will no longer have a power source and therefore it can no longer short and catch fire.
pwstroker69
04-24-2015 07:50 AM
fordman1090
05-29-2008 08:24 PM
