1998 F150 supercab 4x4. Newbie with this body style.
Hey guys, I've been looking and searching and I finally made a purchase. I have a 1998 Ford f150 XLT Supercab, shortbed, 4x4 off-road, 4.6 Triton v8, Auto trans, electronic 4x4. 140,000 factory miles. Only problems are the temp gauge in dash is not working, front bumper is faded, tailgate is alittle beat up (body is straight with no dents), and drivers door lock cylinder has come loose from the inside. I bought the truck for $3800.00. Only thing potential major problem i've found wrong is the rear axle roars. So its either low on oil, or a bearing has gone out and needs a new ring and pinion. But still I feel I got a fair price.
I'll put more pics up tomorrow.
I'm a newbie to this body style. What do I need to look out for? Any advice? ect ect. Thanks guys!
on
Great looking truck, and only 140k. Seems like a good deal, but I wouldn't count on the diff just being low. Check it before possible metal shavings destroy the spider gears or LSD clutch pack.
My only advice; make sure you are in neutral when you shift into 4 low. I have not done it, but, but it seems easy to hit 4 low if you aren't paying attention while twisting the dial and driving, to go one click too far.
It's probably a simple 8.8 non locker.....one wheel wonder. ( I have the same truck only 8' bed). Look at the axle tag...it will probably say S862B, then below that 55 8.8 and something else. 3:55 ratio...8.8 one wheel wonder....or something similar. I just rebuilt my whole rear end with all new bearings due to a whine on accel between40-55 mph. All was good for a month or so....now she's whinin' again. I knew I should have done the ring and pinion....they were as shiny as glass... Explain your noise a little better maybe I can help.
Its the bearing in the pinion. :/ But anyway, Here is some more pics.
And the VIN # is: 1FTZX18W8WNB07858
Nice ...looks exactly like mine. My rear seat and back portion fold down to make a big level platform......never use it that way since it is full of tools and parts...but always thought that was neat. A guy could put a little mattress back there and somewhat sleep back there if he had to...LOL.
It has the 8.8 rear end. 3.55 gearing limited slip. Good news is I have a set of 3.55 8.8 gears laying around. Lol. So all I need is bearings. I was hoping for 3.73 rear end.
I do plan to paint the bumper cover, grill and headlight ring, and mirror covers, They are faded. I also plan to get new "4x4 off road" stickers.
Only other problem I've found with the truck is after driving awhile, when taking off from a red light the drivers side exhaust smokes blue smoke alittle, So I'm guessing the oil drain holes in the head might be partially stopped up. So here soon I'll be pulling off the valve covers and taking a peke inside.
