2000 Ford Explorer - Violent Shaking in steering after hitting bump or 60+ mph - Ford Truck Enthusiasts Forums
Old 02-27-2013, 08:36 PM
Blake Phipps Blake Phipps is offline
Blake Phipps is starting off with a positive reputation.
I just had vehicle inspected and replaced the wheel hub assemblies on the front Left and Right wheels in order to pass. Now while driving strong shaking occurs occasionally when over 60+ mph or at any time after a hit a bump in the road. have to slow down below 30 for it to stop.
Old 02-27-2013, 08:47 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Death wobble....
My '98 did this and it turned out to be the combination of poor wheel balance, worn ball joints and too high tire pressure. Pulled the tire pressure down to and the problem "went away". You should be so lucky.
Ball joints, tie rod ends, the rack and it's mount are suspects, along with bent wheels and fubar'd tires.
Everything needs a close look.
Old 02-27-2013, 09:41 PM
Flash635 Flash635 is offline
Flash635 is starting off with a positive reputation.
What 85e150six4mtod said.
But I would think if too high tyre pressure was causing a problem then you might have belt separation which would also cause a wobble.
That and loose wheel nuts.
Try moving a back wheel up to the front to see if that stops the wobble.
Old 02-27-2013, 09:43 PM
@85e150six4mtod
What do you call too high tyre pressure?
We don't want a repeat of the exploder days.
I use 36 to 38 psi in 235/75/15s and about 34 - 36 in 255/70/16s.
Old 02-28-2013, 12:22 AM
I had one at 39. Try 30.
Ford spec'd 26, and owners didn't check them, letting many drop to 15!
30 (or even 26) is fine as long as you maintain it and don't let it drop off.
Old 02-28-2013, 02:00 AM
26 psi is too low regardless of what Ford says.
When I bought my first Explorer it had 28 in the tyres and it bounced around badly. It also had the original shocks though.
I'd use no less than 32.
Old 02-28-2013, 05:12 PM
Thanks for the input. Im getting it back up on the lift tonight to try and address what ever issue is causing this...
2003 Ford F350 7.3 shaking... XL-D 1999 - 2003 7.3L Power Stroke Diesel 16 07-30-2012 08:29 PM
Billstein or Rancho 9000 or Fox F350Jay 6.7L Power Stroke Diesel 11 07-25-2012 10:24 AM
front end death shake coreylasalle 1994.5 - 1997 7.3L Power Stroke Diesel 15 08-11-2010 07:38 AM
Front end shaking violently Black88GT 1999 to 2016 Super Duty 13 10-01-2004 05:27 PM
1998 Ford Expedition shakes at 60 mph boroarke Brakes, Steering, Suspension, Tires, & Wheels 0 07-15-2003 04:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
