Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > New England Region > Massachusetts Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Massachusetts Chapter Join Chapter, Leader: donjamer
  #1 (permalink)
Old 02-27-2013, 05:41 PM
06F150CFCT 06F150CFCT is offline
Garage is empty, add now
06F150CFCT is gaining momentum as a positive member of FTE.
Somewhere I can get 4.88 gears done
Hey Fellas,
I was curious if anyone knows any place in Mass/RI/CT...screw it, New England....where I can get front and rear 4.88 gears installed on my 2006 F150 FX4. I have talked with a place in Shrewsbury, MA called Mitchell Drivetrain that quoted me $2632.38 for everything but that seems wicked high. I know people in LA can get it done for 2100 and people in Oklahoma and Texas can get it for 1700-2000. I understand everything is more expensive up here and that shops are a dime a dozen but there has to be other shops. I am just looking for other places that would be trustworthy as I am not going to just drop it off at any ol' shop and have them do it.
Thanks for any advice/options.
  #2 (permalink)
Old 02-28-2013, 02:31 PM
BIGKEN's Avatar
BIGKEN BIGKEN is offline
So Little To Say!!!
BIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputation
Try Scott Beck at Beck's Automotive in Greenfield...413.522.1864. Scott used to work at our dealership...Master Certified Diesel Technician. Tell him that Ken from Ford of Greenfield referred you.
__________________
Member of the Massachusetts Chapter and Number One Winter Hater!!!
Illegitimi non carborundum!!!
  #3 (permalink)
Old 02-28-2013, 02:50 PM
Quote:
Thanks BIGKEN...appreciate the help. I'll get in touch with him if this place in CT (CT Axle) doesnt get back to me or work out.
  #4 (permalink)
Old 03-12-2013, 10:36 AM
batchman batchman is offline
batchman is starting off with a positive reputation.
And only a little closer than Greenfield is:
Elias 4WD Center
178 Wallace Hill Rd Townsend, MA 01469
978-597-8432
I've found them to be spendy too, but what you seek is a spendy job.
- Jeff
__________________
Old and Busted: 1-owner 84 Bronco modded 351W, 33's featuring rockers held up by seatbelts.
New Hotness: 86 CCLB DRW Banks IDI C6 4L10.
  #5 (permalink)
Old 05-08-2013, 08:12 AM
BumpJr BumpJr is online now
BumpJr is starting off with a positive reputation.
Im sure this job is already done but just to add. Mitchell's is a great shop and stand by their work. I'm not sure about gearing but they made all my custom axle shafts. Elias is also another great local 4x4 shop. Have no experience with Becks.
  #6 (permalink)
Old 05-10-2013, 03:08 AM
kastein kastein is offline
kastein is starting off with a positive reputation.
kastein
Wow, how's it going Bump? Had no idea you were on here.
There is also Wzorek's in Westfield MA. I have heard good things about them from a few people and reportedly as of a few years ago, they would do a diff for $175 if you supplied parts/install kits etc and brought them the axles out of the the truck.
Mitchell's is out near me, they do quality work (I had them cut down and rebalance a driveshaft for me a few years ago) but that does seem expensive.
  #7 (permalink)
Old 05-10-2013, 09:15 AM
Not bad Ken. Ford fan first. Jeeps second.
I've heard mixed reviews about Wzorek's but no personal experience.
By the way Happy Birthday Ken.
  #8 (permalink)
Old 05-11-2013, 05:17 PM
kastein
Thanks!
06F150CFCT - I believe an 06 would have a high pinion 8.8" front and a low pinion 9.75" rear? What brand gears did Mitchell say they would be using? I see USA Standard (reportedly louder gears) 4.88s for around 160 a diff on RockAuto and Nitros on JustDifferentials for around 260 a diff. Add to that a master install kit for each diff (150/front and 250/rear) and possibly around 100/diff worth of other materials (RTV, lube, bearings to make setup bearings, etc) and the materials should cost around 1100 bucks I believe. Beyond that it is labor - gear setup is not easy, but it's not incredibly difficult either if you are patient. If you have access to a lift and the tools there is a good chance you can do it yourself with some patience/attention to detail, but expect to spend at least several hours, probably a day on each one, that's how long it took me to do my first (and so far only) diff regear.
It doesn't appear that FMS makes 4.88s for the 8.8 (that I can find anyways) but Motive and Strange also appear to.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
