Changed fuel lines-won't start-Air in lines?
Changed all fuel lines on top of my 97 F250
It has a veggie oil system on it, so I have more hoses, as well as the solenoids that switch between diesel and veggie oil. We were careful to mark lines, but I'm gonna triple check it all again..Also had fuel bowl out to get at those lil hard to reach lines.
Anyways, got it all back together, it started right up, ran maybe 5 minutes and died. We thought air in lines, so went through a can and a half of ether. Still won't run. I stopped, as I thought that should have been enough to pull fuel through.
Am I wrong? Could there still be air in lines?
Thanx again Fordman. In case you haven't figured it out yet, I'm not any kind of mechanic....just a dumb bricklayer tryna keep a truck running....
So, after burning up my eyes here all night, I'm seeing how right you are about the ether.
It still turns over no problem. Fuel pressure sensor is filthy, with crack in wire, so I'm gonna change it in the morning, as well as the fuel filter, as it sat on a bench all day while we fooled with truck. Not sure if it matters, but it's almost due anyways.
I guess next step is seeing if fuel is getting to the bowl?
I'm certain we got all lines hooked up right, but forcing the lowest fuel line on required some jiggling and movement of the fuel bowl we disconnected to access it. I can't help but wonder what I could have dicked up doing this.....
Any help is much appreciated.
Matt
Matt
Do you have a wait to start light? When you had the fuel bowl out you could have jiggled the heater wire loose inside the fuel bowl. When that happens, it shorts out and blows fuse 22 under the hood. That fuse also powers the pcm. If you have no wait to start light, replace that fuse and unplug the heater.
Hey Fordman, I wasn't tryin to be a smartass!!
I am really this technically inept.....I see now that I didn't answer that question. Sorry.
I think you may be right about fuel pump. Just hopin there's some way to test it. Dealer put it in 3 months ago, but I'm sure it could still be bad.I changed fuel lines from fuel pump and now truck won't start. All troubleshooting points to bad fuel pump, but it's only 3 months old, so I just wanna make sure I didn't screw up when I was putting it all back together.
Here's what the pic shows-and it's taken standing on passenger side
line 1-goes down to metal line on driver side of fuel bowl and then towards front of truck
line 2-goes to VO tank
line 3-goes into T with one end going down to fuel pump
line 4-goes into the T shared with 3
line 5-goes to VO tank
line 6-goes into fuel control manifold, which is attached to drivers side of fuel bowl
I'm tryin to track down a drawing and double check my lines. As embarassing as it would be, it'd be alot easier if I screwed that up rather than have to change that pump...
I know you weren't trying to be a smartass, I wasn't either. I guess all I can say is double and triple check all your lines. I have no idea how that system works, and am not going to be much help in diagnosing that. It is possible that the pump is bad though, you wouldn't be the first one to have one not last long. It happens.
