'55 F250 Francesca
No worries, just had never heard of that and thought maybe I was misinformed. It could be possible with a 60 but I know I have switched 44s in without a shortening. Great looking truck btw.
Not much for an update, just a lot of waiting around. I did get a new aluminum radiator installed, took a little finagling to get it to fit, but it's in and doing a great job so far. I do have a couple questions that have come to mind regarding suspension though:
I know most people recommend to start at the second leaf up from the axle and take out every other one from there when lowering the rear, but would there be anything wrong with just taking the top spring pack off entirely? Might seem like a dumb question, but it looks to me like there wouldn't be any problem with it.
Second, everything I've seen says F100 front springs are the same as those for an F250, can anyone verify? Are they the exact same or does the F250 have more leaves?
Thanks in advance
Thanks in advance
I just checked my master parts catalog.
1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage
(Well worth the $22)
And it says the typical front springs are the same for F100 and F250. I don't know for sure though. I just counted my F250 stock front springs and they have 9 leaves.
Well SHOOT!!! I just checked my 54-55 Shop Manual (Another must have) and it says Standard for F100 is 8 leaves with 950 lb capacity. Standard on F250 and Optional on F100 is 7 leaves with 1050 lb capacity. So, time to have someone that knows what they are doing to come in and answer.
I know if you're swapping from a Timken to the Dana you'll have to shorten your driveshaft by an inch, not sure about Dana to Dana but either way a good drivetrain shop shouldn't charge more than 40 or 50 bucks to shorten it (also heard of guys shortening their driveshafts in the garage with pretty basic tools. Not sure if I'd attempt that one)
#28
Length/width are the same for the front springs on a F100/250. I have used both setups. They interchange. The only difference I found was the springs were a little thicker on the F250 springs. Since I derate my spring packs for a softer ride I don't thick it matters much.
#29
Harrier,
