Got the master cylinder on my F100 replaced and now the brake lights stay on, why? - Ford Truck Enthusiasts Forums
Old 02-26-2013, 10:20 PM
Vsanzbajo's Avatar
Vsanzbajo Vsanzbajo is offline
Vsanzbajo is starting off with a positive reputation.
Any ideas why? Today after I picked up the truck from the mechanic. I realized that when I parked my brake lights were on. Even after i shut off the engine.
I then pressed the brake pedal ant they came off. No power brakes.
Any ideas what is happening?
Thanks in advance
Old 02-26-2013, 10:35 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Does your truck have power brakes?
Old 02-26-2013, 10:44 PM
Vsanzbajo's Avatar
No power brakes.
Old 02-26-2013, 11:05 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
'had that issue with my 68 Mustang... had a sticky brake light switch.
Old 02-26-2013, 11:06 PM
Vsanzbajo's Avatar
How do you fix that?
Quote:
Old 02-26-2013, 11:08 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
Sounds like brake switch is shorted or improperly adjusted . Ck brake lamp switch .
Old 02-26-2013, 11:20 PM
peckman peckman is offline
peckman is starting off with a positive reputation.
break light
you may have air in the area of the switch. try bleeding the master or loosen the switch on the line and bleed it like you do the calipers.
Old 02-26-2013, 11:33 PM
JWC 3's Avatar
Quote:
Does his truck have a hydrolic brake switch ? It may be stuck or shorted . I thought they were on the pedle assy like my 78 . Ck brake switch anyway , sounds like your problem .
Old 02-26-2013, 11:40 PM
HIO Silver's Avatar
Quote:
Old 02-26-2013, 11:58 PM
look below the master cylender near the stearing shaft there should be a block the lines screw into it was not normal for these trucks to have them....if there is one on the pedal assembly then pull up on the pedal and see if the lights go out...if it does you can just adjust the switch closer to the pedel arm.
Old 02-27-2013, 08:25 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Got the master cylinder on my F100 replaced and now the brake lights stay on. Why?
Today after I picked up the truck from the mechanic, I realized that when I parked my brake lights were on. Even after I shut off the engine.
I then pressed the brake pedal and they came off. No power brakes.
The brake light switch is now out of adjustment after the master cylinder was replaced. Typical.
The switch (D2TZ-13480-B / Motorcraft SW-691-A) is threaded and adjustable.
It's located on the brake pedal itself, threads into a retainer (C8TZ-13A629-A) that attaches to the pedal.
1964/72 Ford Truck Parts Catalog / Illustration Section 75, Page 21 ~ 1969/72 F100/350 Brake & Clutch Pedals & Related Parts.
Fordification.com has this catalog on their website, take a look-see at this parts catalog pic.
(sigh) Pay no attention to info in posts 7 & 10. Has nothing to do with it and it's malarky!
Old 02-27-2013, 08:37 AM
19704X4F250's Avatar
19704X4F250 19704X4F250 is offline
19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all
Quote:
Originally Posted by NumberDummy View Post
The brake light switch attaches to the brake pedal and is adjustable as it has threads.
Yep ND is correct on this one. Unhook the wires to the switch, rotate the switch clockwise to get the switch closer to the stop so there is 1/16" clearance. Simple.
Old 02-27-2013, 08:52 AM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
Look on the brake pedal, about 1/2 way up. Like mentioned, likely the pedal is hanging closer to the floor and the switch needs adjusted down to touch.
You should be able to hear the switch click when you push it. Turn it down til you hear it click with the pedal up.
Old 09-25-2014, 11:38 PM
gstirewalt gstirewalt is offline
gstirewalt is starting off with a positive reputation.
I have kind of the same issue but I think the brakes are sticking or something when I press the brakes the peddle dose not appear to return and I don't think the rear drum brake release all the way. but if I pull the peddle up with my foot feels like the brakes release. any Ideal what I should be looking at? The return spring in the rear drums the power booster?
Old 09-26-2014, 11:12 AM
quinletc's Avatar
quinletc quinletc is offline
quinletc is starting off with a positive reputation.
Check to see if ND's instructions solve your problem.
If it turns out to be properly adjusted already, go with HIO's suggestion.
"Take these three items, some WD-40, a vise grip, and a roll of duct tape. Any man worth his salt can fix almost any problem with this stuff alone." - Walt Kowalski
Brake lights staying on THAT.GUY 1967 - 1972 F-100 & Larger F-Series Trucks 15 12-26-2015 11:29 PM
2007 Escape brake lights stay on? Parkerjohnnie50 Escape & Escape Hybrid 8 07-29-2015 09:23 AM
Emergency brake light Powerstoke73 1999 - 2003 7.3L Power Stroke Diesel 15 10-26-2014 09:28 AM
ABS & Brake lights come on 351Cleveland C4 Ranger & B-Series 1 07-01-2014 08:28 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
