Tire wear problem
Tire wear problem
The outside shoulders of both front tires on my '67 f100 are showing excessive wear. My entire front end was rebuilt in 2010 and a professional alignment was done by a national chain tire shop. The old girl drives true and straight...no pull in either direction when I let go of the wheel at normal driving speed. Is this kind of tire wear indicative of a bad alignment or caused by her tendency to heel over in turns due to her weight? ....she's only gone abt 3000 miles on good roads since the alignment. Thanks in advance for any help/advice.
Thanks to both responders.... I'll double check my tire pressure all around, if it's good or not, I'll be getting my alignment rechecked. I'd hate to destroy my Michelins....they're not cheap. And yes, BruteFord....the outboard shoulders of Both front tires are showing excessive wear - without cupping.
Run your hands across the top of the tire and feel the tread. If it grabs your hand more pulling it out then pushing it in then your tires are "feathered" and have too much toe. FWIW, I'm in the habit these days of running my palm on the tread quite often.
Next would be to look into camber, it absolutely could be caused by the truck "healing over" in turns, in which case more camber is in order. However the wear would tend to be rather equal front to rear if this was the cause. That is unless somehow the front has positive camber(out at top).
on
Nope....didn't replace the springs when I did the rebuild.....and I was always told to never heat and bend the beams, as that will take the temper out and cause them to be easily bent in the future, causing you to constantly have to bend again.... if that's not true, I'm willing to learn.
on
pictures of abnormal wear patterns
here are some pictures of mine
here is the front edge of the drivers front tire. you can see it is tapered off compared to the rest of the tread.
here is the passenger side. it is worn more.
heres the passenger side again, in the picture it is hard to see, but it is worn 3 lugs at a time, like a sawblade. the tall side of the feathered lug hits the ground first.
