Dead in CA
Dead in CA
I'll start with I'm absolutely not a mechanic by any means, I can however follow directions if they are simple... I was able to do the "quarter fix" for my valve cover pin problem for my injectors a few years back.
So last few times starting truck it would turn over but not really "fire" until 3 tries or so. I've had the CEL for my "even side" glow plugs for some time. They all came on at the same time so I figured it was the relay and since I live in southern CA wasnt worried about it. All was ok until we drove to Big Bear and spent 3 days in the snow and well below freezing temps.
Went to start and no luck. turns but no fire. End up toasting batteries and starter trying. Get towed home, replaced the bad battery (not both, just the one autozone would replace, they said other was still good... i know..) and starter, truck fires right up blows white smoke for a while, I take it for a drive and smoking stops. truck starts fine and drives great. Next morning its 32 degrees and no start. plug in block heater for 3 days try to start in 58 degree and no luck. turns but no fire.
Stranded in the driveway...
I was just reading about the fuel gelling up... I think I got hung up on the GPCM. The battery issue and then starter only complicated it. As of now i'm headed out to check the fuel filter and see if it's gelled. I did open the water seperator and fuel came out without issue. If i was able to start it 3 days ago and it hasn't been below say 35 degrees since would the fuel still gel? and if so how can I tell besides the fuel filter?
Thanks for helping....
so you're saying watch for significant drop when cranking? on the voltometer in dash? mine has wide ranges, not real specific numbers but i'll go see how much it drops when cranking...
At that those temps I'm sure your fuel did gel up. It only happened once on my truck when it was in the single digits. I didn't have any problems after adding the 911 and it warmed up a bit. Check out this link: DIESEL 9?1?1® For Winter Emergencies: Winter Rescue Formula ? use to reliquefy gelled fuel and de-ice frozen fuel-filters.
I think the ford manuals says around 9.5v. I'm curious where the 10.5 came from? Maybe the internet and it has to be true... I think other factors like temp would also be a factor.
