exhaust questions
Old 02-26-2013, 04:13 PM
ryanwiss's Avatar
ryanwiss
ryanwiss is offline
exhaust questions
so im putting all new exhaust on my 54 f100 but i was wondering what you guys have done and found was easiest to put on and what had a great sound. i was thinking long tube headers and a manual cutout and exhaust of some sort but i dont want to but long tube headers and find out they dont fit. but it has a 351 windsor bored 4 thousands and has a mild cam, please shoot me so advice on what you think would work the best
Old 02-26-2013, 05:54 PM
48 Steel's Avatar
48 Steel
48 Steel is offline
I've installed duel dynomax VT's but haven't heard them on my truck. You can get a sound bit on the internet of these mufflers. I am running Sanderson headers on my 351M Stroker.
_____________________________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
"Happiness - 3 pedal and a 5 speed"
Old 02-26-2013, 08:55 PM
ryanwiss's Avatar
ryanwiss
ryanwiss is offline
i was on summit today and looked at flowtech headers and then i was gonna weld on a pypes x pipe then it comes back to a manual cutout and 2 pipes back for mufflers
Old 02-26-2013, 11:56 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Ryan,
Hmmm Exhaust stuff.. My only thought would be to avoid cheaping out & just turning down the exhaust under the bed. We tried that one - no thanks - stunk up the cab & sprayed rocks/gravel everywhere. We had to run the exhaust a second time out in front of the back wheels because we had relocated the gas tank under the bed.
Need to be a bit more careful on muffler & noise if it's coming out right behind your door/window. If it's going out the back - use whatever.
Good luck over there.
Ben in Austin
1950 F1
Old 02-27-2013, 12:57 AM
old_dan's Avatar
old_dan
old_dan is offline
I went with shorty headers up front, then 2.5 inch tubing through glass packs & out the back:
Old 02-27-2013, 07:12 AM
jniolon's Avatar
jniolon
jniolon is offline
old and in the way
Dan,
there should be shop rag padding between the lift pads and the frame.... too pretty for lift scratches on the frame rails !
john
Old 02-27-2013, 09:17 AM
old_dan's Avatar
old_dan
old_dan is offline
No worries.. The pads have rubber inserts! Not to mention the POR is tough as nails.
Old 02-27-2013, 05:30 PM
ChuckRob's Avatar
ChuckRob
ChuckRob is offline
We got a set of the block hugger headers from Speedway. they don't flow the best but they fit. They collect down to a 2.25" pipe and thats what we used for the whole system. We were going to use Flowmaster 50's however while crusing the net one day we found some Thrush mufflers that were less than half the price of the Flowmasters and Thrush has been around for ever so I gave they a try. Well the truck sounds just the way I want it to, nice low rumble. The only draw back was the made in China sticker on the muffler box, oh well.
Old 02-27-2013, 06:30 PM
fatfenders's Avatar
fatfenders
fatfenders is offline
Whatever you run, if it doesn't sound right a set of SS tips of reasonable size really deepened the tone of my exhaust.
Old 02-28-2013, 11:28 AM
Jag Red 54's Avatar
Jag Red 54
Jag Red 54 is offline
I installed duals coming out the back with a set of Magnaflow mufflers. Very nice sound! Jag
Old 02-28-2013, 12:13 PM
bryanknie's Avatar
bryanknie
bryanknie is offline
I have shorty sanderson coated headers with flowmaster 40's, ford racing 306 with the x cam. Sounds awesome!
https://www.ford-trucks.com/forums/p...ctureid=110057
Old 02-28-2013, 01:22 PM
ryanwiss's Avatar
ryanwiss
ryanwiss is offline
what would sound better x pipe or h pipe or another set up
Old 02-28-2013, 03:04 PM
AXracer's Avatar
AXracer
AXracer is offline
Either X or H pipe shouldn't affect the sound that much, use whichever you have the room for. IMHO long tube headers are for high RPMs not much benefits on the street, tend to crack, not worth the fit hassle over tri Y or block huggers. Sanderson headers are a bit more money, but they are high quality, guarantee fit if they say it will fit and don't require gaskets that typically leak and blow out with other headers. Whatever you buy DEFINITELY get them ceramic coated inside and out!
Old 02-28-2013, 03:37 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Ryan,
I tried the Flowmaster 40's like Bryanknie has but it was super loud - my neighbors
were frowning. We went with more baffles & a more sedate muffler - it's still plenty loud. We've also got a high performance 351W with a mild cam. (It also might be an age thing - I'm over 50 & less interested in noise at this point).
Ben in Austin
1950 F1
Old 03-26-2013, 03:50 PM
89gtstang's Avatar
89gtstang
89gtstang is offline
Jag - What rims and tires are those?!
Everyone else - I see where people use different sets of headers, being new I question how do you know if these were going to fit or not? Hate to be buying/returning headers until you get a set that fits. I'm working on a 55 and plan on a 351W motor and see headers listed on the MidFifty's website but if there are other sets cheaper I'm all for saving money. Hope to do a 2 1/2" exhaust. Love the pics though.
Quick Reply: exhaust questions
