1967 dog dish hub cap
C7AZ-1130-A .. Hubcap-Same as above except Stainless with Black Accents / 1967/72 F100 Custom Cab/Sport Custom/Ranger/Ranger XLT // 1967 Galaxie/LTD.
1967/77 F250 (same as F350, E250/300/350) hubcaps: Ford_Six has a set on his truck. Has the "crown" in the center, otherwise they're different.
There are two types of these hubcaps for 1967/69 F250's, as there's two types of wheels, 'innies' and 'outies.'
Depends on the year, type of wheels, "innies" or "outies."
Some F250's have "innie" wheels, so called because the hubcap snaps onto tabs located on the inside of the wheel center section.
Some F250's have "outie" wheels, so called because the hubcap snaps over tabs located on the outside of the wheels center section.
The hubcaps appear to be identical for both these wheels, but will not interchange. Ford_Six has one type of these hubcaps on his F250.
They're technically not correct for the F-series but the caps in the first pic below were offered in 1970 (D0AZ-1130-G). Got 'em for $1.50 each! IIRC, the decor panel was $12!
These are later caps were also $1.50 each.. the wheel is a 15x8 Wheel Vintiques Series 62. $83 through Summit.
....And another version offered on the late Dentsides:
I haven't made my mind up on what I'm gonna run. Probably all of 'em!
C8UZ-1130-A .. 'Outie' Hubcap-Painted Argent with Black Accents-11 3/4" O.D. / 1968/69 F250/350 Standard Cabs / 1970/77 F250/350 Customs.
C8UZ-1130-B .. 'Outie' Hubcap-Stainless with Black Accents-11 3/4" O.D. / 1968/69 F250/350 Custom Cabs / 1969/77 F250/350 Ranger / 1970/77 F250/350 Ranger XLT.
Other applications: 1969/74 E300 / 1975/77 E250/350 (E = Econoline). 'New' Econoline introduced in February 1968, but FoMoCo called them 1969's from the get go.
Note: There are two 10 5/16" O.D. "innie" versions of these same hubcaps, were used on 1967/69 F250/350's.
Old thread I know but I am in search of a set of hubs for my f100. I found some 15" ford steel wheels and would like to have close to the originals that came with my rig. If anyone has a set of the two NumberDummy mentioned and showed photos of (dog dish style) I would be interested.
Thanks, Mark
Thanks, Mark
^ C7TZ-1130-G .. Hubcap-Argent with Black Accents-10 1/2" O.D. / 1967/72 F100 Standard Cabs.
