Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-26-2013, 12:15 PM
rossvt's Avatar
rossvt rossvt is offline
1947 Ford Medium Duty
rossvt is starting off with a positive reputation.
next step for 59ab
HELLO NEW TO SITE PLEASE HELP
I HAVE A 47 COE WITH ALL THE ORIGINAL PARTS AS IT WAS PARKED IN LATE 60'S( JUST RUSTY) I HAVE PULLED THE PLUGES AND THE MOTOR TURNS OVER EASY BY HAND. MY QUESTION IS , SHOULD I TRY TO START IT BEFORE LOOKING UNDER THE HEADS. BEING THERE WAS SOME RUST ON SOME VALVES . BUT NO WATER IN THE OIL OR CYLNDERS .
WHAT IS THE NEXT BEST STEP.
THANKS
ROSS
  #2 (permalink)
Old 03-09-2013, 08:28 AM
petey shoes petey shoes is offline
Garage is empty, add now
petey shoes is gaining momentum as a positive member of FTE.
ross, put about an ounce of atf-automatic trans fluid-in each cyl. spin it over half a dozen times, let it sit at least overnite. this will loosen up any "crud" around rings. make sure the oil is clean, then, IF nothing else concerns you---fire it up! keep an eye on oil pressure. if guage does not work on truck, hook one up direct to engine---you need to know there is pressure. good luck!
__________________
42 1.5 ton marmon herrington all wheel drive
Tags
59ab, coe, flatheadmotor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
