glow plug removal
02-26-2013, 03:55 PM
on
Could i maybe unplug each and turn key on
02-26-2013, 04:01 PM
on
you could test them through the connector....i dont remember if its power to ground or vise versa.....someone more nutty will chime in im sure!
02-26-2013, 05:59 PM
on
Well thought i.did good till i drove it. Smoking white real bad and sounds awful. What did i do wrung. Still has good power until i try to pull out
02-26-2013, 06:02 PM
on
More a bluishwhite sounds rough
02-27-2013, 07:48 AM
on
did you mess with the injector harnesses under the valve cover? im still leaning toward the connector/harness from my experience recently
02-27-2013, 07:52 AM
on
The new uvch comes with the plugs for the injectors don't it? Im guessing i wrired plus rong on out side.
02-27-2013, 08:13 AM
on
yea,my new valve covers came with everything....these are where my problem was, i remember a member saying his truck ran ok at idle and shoke/had low power with a missing injector
glow plugs are outer most ports....
02-27-2013, 09:04 AM
on
Yes mine did to, so what's this pic meaning towards?
02-27-2013, 09:30 AM
on
when you did the glowplugs, you may have left/knocked of an injector connector, or the pins on the valve cover, or that connector may be screwed up or burnt. did you disconnect anything else
02-27-2013, 09:40 AM
on
Yea i replaced pig tails, replaced all connectors under vc
02-27-2013, 10:05 AM
Sounds like you may have wired the pigtail wrong
02-27-2013, 11:05 AM
on
Got a good scanner, says idm at fault, miss firing ever other cylinder
03-01-2013, 07:58 AM
on
03-01-2013, 02:50 PM
on
Yea, got to looking at it and had the wires crossed.runs great now
03-01-2013, 05:52 PM
Quote:
Originally Posted by
fordpride
f1501987
And the winner was .........
I tried to rep Mike, but NO dice
KennySpencer
22
06-09-2014 12:42 PM
ericbskis
10-29-2013 01:31 AM
Dan Taylor
09-23-2012 06:37 PM
tracyclifton
06-03-2012 11:10 PM
butchf350
03-08-2006 06:26 AM
