Crank pulley questions, Roller 302 with V belts
finishing up on a gt40p roller 302 swap in a 56 f100 and just about done and ran into this problem.
do they make a thinner pulley?
right now it has a mustang style 50oz HB and v belt pulleys that were supposedly from this truck..
what car/truck would have a pulley that i need? and anyone have one?
Well if you were using pulleys from a 56 F100,(no small blocks back then, not until 1962) that was your first mistake. You need a set of pulleys for an "alternator only" accessory drive setup. The crank pulley from a 70's 351 (W, M or C) will have the sheeve that lines up with that waterpump pulley. But since you've spent money on that shiny waterpump, I'd suggest getting a set of shiny aftermarket pulleys instead.
hav24wheel
08-25-2014 12:56 PM
pipman76
09-05-2009 05:43 PM
