95 runnin hot
95 runnin hot
so, when i drive i notice the truck warms more then usual, however when i stop at idle in drive it really warms up. so tonight i decided to let it idle in drive let it warm up a bit for about 30 seconds and once the needle steadied out, put it in neutral and tapped the gas. the temp needle instantly began to drop. would this mean that i need a new water pump?
thanks for any help
thanks for any help
If you get out on the open highway driving 50 MPH or faster, does it run cool then? If it still runs warm then, you can forget the answer in my first paragraph.
Yea it is.. However the unthinkable happened tonight.. I went to replace the thermostat, mind you the truck has always leaked coolant a very small amount since i got it. From what i thiught was a location.. Anyway i went to take off the housing and the bolt sheered off... Nightmare... I tried extractin it woth extracting tool and nothin. Well before that happened i drained a little coolant off from radiator, it came out nasty and rusty.. Another nightmare.. Ive had the truck not that long and way i fogure the old dude who owned it last never did extended maintaince. So now it holds coolant and has a drip about every 45 seconds from where bolt sheered.. One bolt holds it on, so lone be hold i didnt even get to thermostat. Terrible. Ive done alot of projects. This one takes the cake so far, so now i in to i believe a new radiator prolly new hoses and hopefully thatll fix my first problem? Idk right now im just gonna sleep on it i guess..
slothshady
29
08-04-2005 06:29 PM
Overfences
05-04-2002 12:31 PM
