4wd quit working - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
4wd quit working
Old 02-25-2013, 12:18 PM
hogancon hogancon is offline
hogancon is starting off with a positive reputation.
4wd quit working
I have an 01 F250 7.3. The other day when I went to switch it into 4wd the light didn't come on and I had no 4wd. I have been putting the hubs in the lock position when needed for about a year now. I have been reading threads for 2 days. I think it might be in the TC but not sure, and don't know how to test it. The front drive shaft is spinning when driving. Any help would be appreciated.
Old 02-25-2013, 12:22 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Hi hogancon and welcome to FTE.
It sounds like the motor that shifts the transfer case is not working. I would start by checking the wiring harness and making sure the motor has power going to when it should.
Old 02-25-2013, 12:36 PM
Thanks for responding so quickly redford,
Would that be something likely to quit all of the sudden? Just to give you a little back ground on my electrical skills... I have a volt meter, but am not very good at knowing what to do with it. I fried my last one on its first use.lol It looks to me like there are two wiring harnesses going to the TC. Do I need to check both?
Old 02-25-2013, 02:11 PM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Here is a post I wrote a long time ago on diagnosing 4WD shift problems. The fuse numbers are 2002-2004 specific, so they won't apply, but everything else should.
http://www.ford-trucks.com/forums/10...l#post10605244
In place of the fuses I outlined, dig out your Owner's Manual and check any fuse that says anything about the General Equipement Module (might be called the General Electronics Module), 4WD, and anything that is a "feed" (Run/Start feed, etc.)
I may be able to dig up model year specific fuse information, if you hit a dead end.
Old 02-25-2013, 02:26 PM
Thanks dchamberlain, I will check it out and let you know what I figure out.
Squeeking/ humming noise when in 4WD low jadenamsjl18 1999 to 2016 Super Duty 2 01-24-2015 03:20 AM
transfercase problem 1996 XLT brydgy Explorer, Sport Trac, Mountaineer & Aviator 2 03-12-2006 09:55 PM
2001 Sport Trac 4WD Problem RIKen822 Explorer, Sport Trac, Mountaineer & Aviator 2 12-12-2005 07:32 PM
Does A4WD affect gas mileage or advancetrac 026TB4U 1997-2006 Expedition & Navigator 7 05-13-2005 12:03 PM
did I just screw up the transfer case on my new truck? clueless... my96f150 Offroad & 4x4 13 01-08-2005 08:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
