Help with horn issues
Old 02-25-2013, 09:29 AM
unibody madness's Avatar
unibody madness
unibody madness is offline
The 1961-62 f100/250 2wd with floor mounted shifter, has a different turn signal/horn arrangment, than I have found on the three speed column shift set up.
The horn grounding wire (actuator), pictured below is missing in my application.
Thanks to Number Dummy, as well as others, I now know what I am looking for.
The books show the following wire to be part of the turn switch, it is not, but may have originally come with the switch
horn wire
T/S switch installed
horn wire and contact installed
The turn signal switch (CODZ-13341-A), and The steel turn signal mounting plate (CODF-13304-A) that goes above them,was bought several years ago from Green sales but did not come with the wire.
Thanks to Bill (ND), I now know there is no seperate part number for this piece
If anyone has one, or knows where I can locate one, please let me know. I am in need of two (2)
Thanks
John
JIW74
03-11-2024 03:46 PM
P38fighter
05-24-2014 07:45 AM
P38fighter
05-24-2014 07:28 AM
unibody madness
1961 - 1963 F100 Unibody
03-14-2013 10:12 AM
udownwitjesse
07-10-2011 08:02 AM
Quick Reply: Help with horn issues
