Help with horn issues - Ford Truck Enthusiasts Forums
Old 02-25-2013, 09:29 AM
unibody madness's Avatar
unibody madness unibody madness is offline
unibody madness is starting off with a positive reputation.
The 1961-62 f100/250 2wd with floor mounted shifter, has a different turn signal/horn arrangment, than I have found on the three speed column shift set up.
The horn grounding wire (actuator), pictured below is missing in my application.
Thanks to Number Dummy, as well as others, I now know what I am looking for.
The books show the following wire to be part of the turn switch, it is not, but may have originally come with the switch
horn wire
T/S switch installed
horn wire and contact installed
The turn signal switch (CODZ-13341-A), and The steel turn signal mounting plate (CODF-13304-A) that goes above them,was bought several years ago from Green sales but did not come with the wire.
Thanks to Bill (ND), I now know there is no seperate part number for this piece
If anyone has one, or knows where I can locate one, please let me know. I am in need of two (2)
Thanks
John
Bow's 1973 F250 build bruggeri 1973 - 1979 F-100 & Larger F-Series Trucks 17 04-02-2014 01:04 PM
TheGageinator's Build thread with PICS!! TheGageinator 1987 - 1996 F150 & Larger F-Series Trucks 48 02-01-2014 07:50 PM
Horn doesnt work ----w/pics Caniac10 Excursion - King of SUVs 3 06-20-2012 03:35 PM
56 F-100 Front Spring Perch Bushings?? AmericanROCKBREAD! 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 02-16-2011 02:38 PM
Transmission Color - What do YOU do? AmericanROCKBREAD! 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 01-30-2011 08:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
