223 Mileage??
Old 02-24-2013, 05:26 PM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
223 Mileage??
Common guys what are you really getting with "the mileage maker"
Please include rear gear if you know it.
Old 02-24-2013, 06:15 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Panties NOT in a Twist
Talking
Who are these "common guys" you refer to?
We are , after all , fridge owners, so we're a bit off to begin with.
Old 02-24-2013, 06:45 PM
spurredon's Avatar
spurredon
spurredon is offline
Being uncommonly common, I have never really checked it out. A big part of my driving is on rough back roads though. I think I get around 15 but not really sure. Hopefully, if the weather cooperates and all the snow is gone and the roads are free of the killer salt, I will find out sometime, alas, prolly not before April though.
Old 02-24-2013, 07:34 PM
Damifiknow's Avatar
Damifiknow
I meant to say "Come on" not "common".
Old 02-24-2013, 08:32 PM
hiball3985's Avatar
hiball3985
hiball3985 is online now
I average about 15 around town, 18-19 on my last long trip. It use to do better with the old leaded gas 21-22mpg, the Calif blend sucks.
I'm running a 3:89 rear with an overdrive trans.
Old 02-27-2013, 02:15 AM
59pu's Avatar
59pu
59pu is offline
I never saw close to 20 when running my 223 (3.73 3spd. stock tires). But I always believed there was something wrong with it. It never had any power either. Did rings & valve job & timing chain. Checked cam lift & timing...never happy. Swapped for 8cyl & OD never got mileage but happy w/ power.
Old 02-27-2013, 09:44 AM
FJones8668's Avatar
FJones8668
FJones8668 is offline
I was able to get real close to 18 but that was with the smaller diameter 1b carb. Since I put the larger non-mileage-maker 1b carb on it seems to have dropped down to about 16. I do like the little extra power though. both with 4.10 gears and non OD tranny's.
Edit: most of the roads around here seem to be old Ford friendly because the speed limits are mostly 45-50 with the occasional 55.
theshyguy
6.4L Power Stroke Diesel
17
12-17-2010 09:39 AM
pass-thru
2010 - 2014 Ford SVT F150 Raptor
08-09-2009 03:26 PM
abah
2004 - 2008 F150
02-28-2006 05:58 AM
DOHC
Oil & Lubrication
02-09-2005 10:53 PM
Quick Reply: 223 Mileage??
