Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 02-24-2013, 10:15 PM
Nabendroth Nabendroth is offline
Garage is empty, add now
Nabendroth is starting off with a positive reputation.
1959 Ford F100 Diesel Conversion Questions
I've got a 1959 Ford F100 on a 4x4 chassis. I know its not an original frame to the truck but i know its a 4x4 chassis. Possibly a 4x4 chassis from another 59'. I have a parts truck for the conversion. It is a 87' Ford F350 4x4 lariat I believe it has a 7.3L idi motor automatic trans and a gear vendors overdrive system. I am wondering if anyone here as embarked on a conversion like this. What is the easiest way to go about transplanting it? is there a engine and transmission mount already produced to get the engine and trans mounted or is that going to need to be fabricated?
Any help or suggestions would be great. Here is a picture of the 59' that I will be doing it to. I will get pictures up of the engine bay area tomorrow.
Click the image to open in full size.
  #2 (permalink)
Old 02-24-2013, 10:47 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
In Memoriam.....
ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.
Welcome to FTE. I cannot give you any help, but member GB Sisson, a.k.a. Gary will be along in a while. He probably can steer you in the right direction. I do know he has done a diesel conversion, but don't know which motor.
Steve
__________________
"Why, yes, I have plenty of spare change, you worthless piece of crap."
'59 F250 w/an Engine, a Transmission, Some Tires/Wheels, PLUS-a Genuine Radio
" Entitled, self-absorbed kids - meh."
  #3 (permalink)
Old 02-24-2013, 10:48 PM
GB SISSON's Avatar
GB SISSON GB SISSON is online now
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Let me be the first to welcome you! And photos on your FIRST post? Wow. And a nice clean truck, btw. OK, well I'm gonna be your ally here. I just converted my '59 to diesel. It's a long haul, with a lot of engineering and I'm not really sure the f100 frame will be adequate for that big ol' 444 cu in oil burner. Like you, I also have a '92 f350 4x4 diesel. That's a whole different animal than an f100. My conversion put a scrawny 120 hp cummins six (6at) in a '59 f350 chassis. The frame and running gear are overkill for that powerplant. So..... I would look really hard at what it would take to put the '59s cab on that parts truck. It's not easy by any means, but you'll end up with power brakes, dual master, power steering, heavy frame and running gear, frame mounted fuel tank, lots and lots of stuff people take great pains and $ to add later. Not saying it can't be done either way, but that's just my .02. I actually thought just today about putting my new parts truck cab on my '92 and building a flatbed for it. Not that I need another truck, I'm just a chronic tinkerer. I have both of your same rigs, so I can help you with measurements as well, either way. More pics please.
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #4 (permalink)
Old 02-24-2013, 10:51 PM
GB SISSON's Avatar
OK, the second one!
__________________
  #5 (permalink)
Old 02-24-2013, 10:53 PM
ibuzzard's Avatar
In Memoriam.....
Quote:
Close but no cigar! But you may proceed......
Ya gotta watch out for him, though, as he can be a bit "wordy"..........LOL!
__________________
  #6 (permalink)
Old 02-24-2013, 11:04 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is online now
theodore/teddy is starting off with a positive reputation.
I didn't want to be first, but welcome just the same.
Good to see another fridge getting a little attention!
Good luck in your quest!
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #7 (permalink)
Old 02-24-2013, 11:45 PM
GB SISSON's Avatar
Who, Me? It's been brought to my attention that I talk in my sleep as well.... Oh wait, do I count 8 lugs and a full floater? 3/4 ton...axles or frame also? How will we know.
__________________
  #8 (permalink)
Old 02-25-2013, 11:26 AM
Thanks all for the welcomes!!!
The 59' is sitting on an 8 lug chassis. So I would assume it is a 3/4 ton chassis. correct me if I'm wrong though. The frame on the 87' is a bit longer then the frame on the 59' as the parts truck is a crew cab/long bed. Here is a picture of the front frame section on the 59'. Let me know if there are any other pictures needed. Thanks
  #9 (permalink)
Old 02-25-2013, 11:40 AM
Nab that looks to by a fridge frame.
The rear shock mounts for the front axle are not stock.
The radiator support mount stud is the type that utilizes a spring, which is seen on the 4x4's and f350 and up frames.
What is the number on the top frame rail below the battery box, and does it match the data tag on glove box door.
Is that front diff a high pinon?
I think Gary has so good info for you to consider.
__________________
1959 F250 4x4
Wally
  #10 (permalink)
Old 02-25-2013, 03:01 PM
Ok now I am confused. Both vin numbers match (frame and glove box). I thought the vin would start f11 if it was an f100 4x4 but it does not. But it does have the transfer case and front axle for a 4x4 setup.
So now that we know that for sure how is the engine mounting situation going to change? is it going to be harder? I heard there are companies that produce the necessary mounts to mount the engine. I'm assuming I'm going to have to be fabricating something to mount the engine.
Btw thanks for all of the help and advice thus far.
  #11 (permalink)
Old 02-25-2013, 03:18 PM
Not necessarily in the vin, mine for instance show f25. (F280 in model code)
But in the model code, second line between color and date.
__________________
1959 F250 4x4
Wally
  #12 (permalink)
Old 02-25-2013, 04:53 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Welcome to FTE. You don't happen to be a woodworker for a living do you? I might think you are Gary's long lost brother!
  #13 (permalink)
Old 02-25-2013, 04:57 PM
GB SISSON's Avatar
It's hard to imagine a company makes aftermarket motor mounts to put the IDI in that frame, but I've been wrong before. I'm an amature welder and I made some serious mounts to put the cummins six in mine. I just considered it part of the fun. I hate waiting for the UPS truck, so I pretty much just make everything out of scrap I have laying around. It gets done faster that way! Enjoy the process, I miss that part of my project now that I'm sealing roof seams and replacing door glass. (awful job).....
__________________
  #14 (permalink)
Old 02-25-2013, 04:59 PM
GB SISSON's Avatar
My long lost brother works at the wal-mart in Bradenton Florida........
__________________
  #15 (permalink)
Old 02-25-2013, 05:48 PM
No on the woodworking. I restore mustangs and sell parts for them. I wouldn't think that a company would make that specific of a mount. By chance GB SISSON do you have pictures of the mounts mounted to your frame? How tough was it making the mounts?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
