steering column/wheel differences pre-77 and 78 and up?
Folks,
I am about to order a Grant steering wheel. I notice that their adapter kits make a delineation between 77 and prior and 78 and newer.
Is there a difference in columns or column wiring/internals between these years? The reason I ask is that although my truck is technically a 1979 F350, the cab is from a 77 F100. I am assuming that whoever swapped the cab kept the column that came with it...makes sense to me anyway! So, I may (likely) have a 77 column in my 79.
Is there an easy way to tell what I have so that I can order the right adapter kit?
Cheers,
Roy
Cheers,
Roy
ak ford guy,
no tilt.
v10 man,
i was wondering the opposite! from images that i have been looking at, my steering wheel appears to be a 77 and prior (it sure looks similar), but my column is definitely from a 79 (contacted the p/o and he confirmed he used the 79 column in the 77 cab).
maybe it's because i don't have cruise control that makes my wheel look like the older versions, since number dummy states that the columns and wheels are distinct.
thanks for the replies.
r
no tilt.
v10 man,
r
The early columns had a larger diameter wheel. The horn pad was inset into the face of the wheel. The '78 and up wheel (also fits early '80s models) is a smaller wheel and the horn pad covers the entire spoke of the wheel. The early models were made from a hard plastic molded over the metal spokes and ring. The later ones had a softer plastic fitted over the spokes. It's basically hollow inside when you take the horn cover off.
If you need me to, I could try and get a photo of the face of each wheel and measure them as well.
D4TZ-3600-A .. 15 1/2" 2 Spoke Black Steering Wheel: 1974/77 F100/350 & Bronco, 1975/77 Econoline (except 1975/77 F100/350 & Econoline with Speed Control).
This wheel (repro'd by Carpenter) was also the FoMoCo "Service Part Replacement" for 1971/73 F100/350's that came with blue/black/green/red/tan steering wheels.
1975/77 F100/350 & Econoline used a specific black steering wheel (D5TZ-3600-A), horn pad and turn signal switch (D5TZ-13341-B) with Speed Control.
1973/77 F100/350, 1974/77 Bronco & 1975/77 Econoline T/S switch specific to M/T (D3TZ-13341-A) or to A/T (D3TZ-13341-B), without Speed Control (Bronco not available with Speed Control until 1978).
The horn pads without Speed Control (black camera case finish & wood grained-Ranger XLT & Econoline Chateau only) are the same 1971/77 F100/350, 1974/77 Bronco, 1975/77 Econoline.
E4UZ-3600-A (replaced D8TZ-3600-A) .. 16" 2 Spoke Hard Plastic Black Steering Wheel-Use with Manual Steering: 1978/79 F100/350 & 1978/88 Econoline.
E4UZ-3600-B (replaced D8TZ-3600-B) .. 15" 2 Spoke Hard Plastic Black Steering Wheel-Use with Power Steering with/without tilt wheel: 1978/79 F100/350 & Bronco / 1978/88 Econoline.
D8TZ-3600-C .. 2 Spoke optional Black Simulated Leather SOFT PADDED Steering Wheel: 1978/83 F100/350 Ranger XLT/Lariat, Bronco & Econoline.
Tilt wheel intro'd in 1978, operates by pressing the turn signal handle forward.
1978/79 F100/350, Bronco & Econoline T/S switch (D8TZ-13341-A) is specific to tilt wheel.
T/S switch specific to A/T (D8TZ-13341-B) or M/T (D8TZ-13341-C), without tilt wheel.
D7OZ-3600-A .. 3 Spoke "Sport" Steering Wheel: 1977/79 F100/350 & Econoline, 1978/79 Bronco // 1977/79 LTD II (NOT LTD!)/Ranchero/Cougar/Mustang/Thunderbird/Mark V.
Factory installed Speed Control was not available with this wheel, as it has a round horn button. If people wanted Speed Control, dealer installed was all that was available. Control mounted on the T/S handle.
Dude_Zilla
18
07-13-2022 10:11 PM
Baby Boomer
04-26-2017 01:09 PM
dinosaurfan
07-02-2003 09:22 AM
