Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
  #1 (permalink)
Old 05-31-2003, 08:31 PM
gotpez gotpez is offline
Garage is empty, add now
gotpez is starting off with a positive reputation.
Question Winter driving
I am considering purchasing a 2003 Lightning, but it will need to be a daily driver. Since I live in Ohio, there is some snow to deal with. Not too much, but it is a concern. Does anybody here drive their Lightning in winter conditions? If so, how does it do?
My current vehicle is a 1998 AWD Explorer, so I know the Lightning won't handle the snow like it does, but I do need to get to work even in the winter!
BTW, I did get the opportunity to test drive the Lightning today..... AWSOME!!!! No other way to describe it. In my younger days I owned a 5.0 5-speed Mustang. That was a blast to drive, but this MAY top that car.
__________________
Jeff Gilligan
2003 Red Lightning
2214 of 4270 Born on 3-5-2003
  #2 (permalink)
Old 06-03-2003, 01:02 AM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Winter driving
It'll drive alright because it has a limited slip in the rear. You might want to get some snow tires. I had a 95 F-150 2wd with a limited slip and some snow tires and you could get anywhere except up steep hills and towing trailers in the winter time. A little weight in the back would help too.
__________________
Justin
95' F-150 XLT 4x4, 393ci stroker, 5 spd, 6" lift/35s
  #3 (permalink)
Old 06-03-2003, 08:09 AM
zetec2000 zetec2000 is offline
zetec2000 is starting off with a positive reputation.
Thumbs up Winter driving
Don't forget that when you get snow tires, Wider is NOT better
The best thing I have found for adding weight are concrete patio pavers (usually 2' x 2' x 2") If you have a bedliner, they work great.
Here's what I do (I have a plastic (drop-in) liner):
Completely clean the bedliner, then put a few 'dots' of silicone adhesive on the raised ridges of the bedliner. Lay the pavers on top of the 'dots', and they will stick in place, so they don't slide around in the back. (be sure to use an outdoor adhesive with good low temp performance)
A Pal of mine uses the traditional 2x4 and Sandbag approach, and it works just as well.
Good Luck, and remember that Nothing beats doing donuts in 4" of new snow
~Paris
  #4 (permalink)
Old 06-03-2003, 08:32 AM
Winter driving
Thanks for the reply.
It seems that most people with this truck don't take it out in the snow. Unfortunately, I don't have this luxury, at least now now. I will take a bit more convincing to get the wife to let me get a winter beater.
__________________
Jeff Gilligan
2003 Red Lightning
  #5 (permalink)
Old 06-03-2003, 05:42 PM
Winter driving
I would probably have a lightning if it wasn't for the fact that I need 4wd for winter use.
__________________
Justin
  #6 (permalink)
Old 06-27-2003, 07:10 PM
jsidmore jsidmore is offline
jsidmore is starting off with a positive reputation.
Winter driving
Last fall I had to deal with your situation; I live in NH, drive into the white mountains and everywhere else with my 99 lightning. What worked for me was this: I took a look at the spare tire set up on the truck, i think it is a 235 70 16 (ck for yourself to be sure)I figured the overall size difference would be close and the rim would have to be large enough to clear suspension and brake components, went to a local large volume ford dealer, ordered up 4 spare tire rims only. (price was around $65 each through a friend at the parts counter) next, check out tirerack.com, there you will find a great winter tire from Michellin called the (4x4 alpin) non studed, works pretty good considering you can actually drive the truck at moderate speed, takeoff and braking. I was actually amazed at the hook up on dry and the stopping on snow. worked for me! Also, my truck has a belltech drop kit which makes it even more difficult in deep snow. good luck!
  #7 (permalink)
Old 06-27-2003, 07:19 PM
Winter driving
another note, PLEASE don't ever use any kind of block for weight in the bed of your truck. This becomes an instant projectile in an accident. I could be wrong but I use bags of water softener salt in the bed because it won't freeze like sand will (moisture in it), you can use it if you get stuck and hopefully in the event of an accident, the unfrozen salt bag will disitergrate during an impact...who knows, but its better than concrete...
  #8 (permalink)
Old 06-28-2003, 11:59 AM
Winter driving
Thanks for all the info. I bought my '03 Lightning about two weeks ago. Checked out Tirerack.com and for about $1000 they can get me some 16 inch wheels and snow tires. And on top of that, the wheels aren't just steel spare tire wheels. Not the coolest looking things, but they will be reasonable.
I have a water softener, so using the salt for weight on the back end will not be a problem for me.
Thanks again
__________________
Jeff Gilligan
2003 Red Lightning
  #9 (permalink)
Old 06-30-2003, 10:02 PM
Bikeitswift Bikeitswift is offline
Bikeitswift is starting off with a positive reputation.
Winter driving
I agree withy the winter tire post. I at one time had a rear drive sports car with horrible winter traction. I sprung for a set of Bridgestone Blizzax (or something like that) for all four wheels and they made a LOT of difference . It'll help rationalize the cost if you consider you'll extend the wear on your original tires by every mile you put on the winter ones. I do think the rear end drop or leveling kit makes sense for weight transfer reasons as well. Definitely get new wheels for those winter tires.
__________________
At the Lake
  #10 (permalink)
Old 07-01-2003, 10:47 AM
ArtsBest ArtsBest is offline
ArtsBest is starting off with a positive reputation.
Winter driving
Sure would like to know what the dealers are "getting" for a new $33,500 White SVT 03' Lightning? Edmunds says we have to pay around STICKER. Which I would NEVER do. Any input would be GREATLY appreciated.
  #11 (permalink)
Old 07-01-2003, 03:02 PM
Winter driving
I didn't pay sticker!!!
It all depends on how strong the market is in your area. How bad does the dealer want to get them off their lot? Just don't be in a hurry, take your time negotiating.
__________________
Jeff Gilligan
2003 Red Lightning
  #12 (permalink)
Old 07-02-2003, 05:17 AM
Winter driving
on the price issue, I have portsmouth ford at $32k and then autofair (high, high volume dealer) at $29k (at least the last time i looked...) Prices range. Even at 35k the truck would be a good deal considering its power, handling, braking and in my case it also makes a pretty good work truck for light construction.....
  #13 (permalink)
Old 07-10-2003, 08:47 PM
Michael6thst Michael6thst is offline
Michael6thst is starting off with a positive reputation.
Winter driving
I drive my '01 everyday and wider IS better I had a 94 F-150 and the lightning is MUCH better in the snow....check the PIC
http://www.geocities.com/michael6ths...Lightning.html
  #14 (permalink)
Winter driving
Tags
03, driving, f150, handle, lightning, sandbag, weight, winter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
