GUTLESS 460, any ideas?
130 seems a bit on the low side. I'd expect more like 150, especially with the stock very mild cam. Might want to do a leak down test, maybe your rings may have not seated properly.
I just noticed you said 55 MPH in 3rd. 55 MPH in 3rd with 4.10:1 gears and ~33" tires is 2300 RPM. Let the truck rev man. While it has a lot of torque for a gasoline engine, it's still not a diesel. Your truck should be able to hold 2nd all the way to 65 MPH, 55 would only be 3500 RPM.
My tires are ~31" diameter. In 3rd gear at 55 mph with the torque converter locked I'm just under 2500 RPM. If this truck can't pull a 8000 lb trailer up a light grade at 55 mph at 2500 rpm then either something is wrong or it just wasn't that great to start with. While others might be fine revving their engines, I'm not. My limit (except for passing, etc.) is 3000 RPM, maybe as much as 3200 if I'm in a hurry. That's really irrelevant though, since I believe this engine should be able to pull the trailer up a light grade faster than 55 mph.
I hate to compare with the Chevy again for the sake of the Ford pride out there, and to clarify, I don't necessarily consider Chevy to be a superior product. At one time I had an '84 Suburban with a 454, Turbo 400, 3.73 gears, completely stock. It would have pulled this trailer much better.
I should also mention, the engine is quite snappy at low speeds. I'm beginning to think that there isn't anything wrong with it, it probably just isn't adequate for my needs.
Well, the fuel cut on the EFI 460s is will before 5000 RPM, but yes I agree it does need to rev. 3000-3500 RPM for a few minutes to pull a hill is not going to hurt a 460.
I appreciate all of the responses, I'm at the point where I don't think anything is wrong with it, but if that's the case, it's not going to cut it...I just might see a powerstroke in my future. It's just hard to justify the cost of the diesel for something I drive 5000 miles per year.
and a 454, both of which were rated at lower HP and Torque, and both would out pull this 460 in 3rd gear at 55 mph, all at my altitude.
Maybe it is just me having unrealistic expectations.
Take a look at these graphs: https://www.ford-trucks.com/forums/9...hs-inside.html
It's not a direct comparison since he's running an aftermarket computer and has adjusted his timing accordingly, but the rest of the motor is stock, so it's not out of the scope of imagination.
Since you had mentioned you're towing in 3rd gear, I rounded the your running speed up to 2500 RPM for easier math.
A 460 running at 2500 RPM of a 1000-5000 RPM band means you're running at 37.5% of your usable rev range ([2500-1000]/[5000-1000]=0.375). This is pretty low with you probably making 130-150 HP according to the dyno graphs I linked to. Lets move your RPM up by a factor of 1.538 (ratio difference from 3rd to 2nd) to 3845 RPM (in the meat of the power band Diesel_Brad recommended), and you're not at ([3845-1000]/[5000-1000]=0.71) 71% of the usable RPM. You're approaching peak power with about 180-200 HP available on tap. This is 30-35% increase in power at the wheels.
It hasn't been mentioned much but if your compression is 130 I would say something is seriously wrong. When my 460 was worn out before the rebuild it was around 155 on all cylinders. Now it is at 170 just for reference.
Edit: You should probably retest. Even if the motor was stone cold and at that altitude I don't think it could be that low.
Take a look at these graphs: https://www.ford-trucks.com/forums/9...hs-inside.html...
So, my understanding of advancing cams is that you move your power band down approximately 100 rpms for every one degree the cam is advanced. So if I were to change it to a straight up cam timing, I would probably lose some total horsepower in the high rpms (which I don't care about), but I would gain some power in the 2500-3000 range that I deem more acceptable. I say acceptable range because with the way things are right now, I would be spending a lot of time in 2nd gear at 3500-4000 RPM. According to the graph posted above, I would gain roughly 20-35 horsepower at 2500 RPM. I would also think the gas mileage would be better when driving around empty in overdrive. Anybody see any problems with my logic?
The lock up convertor in the E4od really makes a 460 lug hard. One thing I really hated about mine back then. As soon as it hit 2nd, it locked up and takes the wind out of it. Great for fuel economy back then. Now you can get a switch on the dash to let you choose what mode you want.
#28
#29
#30
It gets pretty warm pretty quick. If you have no cooler, I wouldn't be surprised at all to see 220+. A large trans cooler will help keep the temps in check and extend the life of that transmission.
