Ignition Coil Replacement 5.4L Triton - Ford Truck Enthusiasts Forums
Old 02-24-2013, 06:04 PM
SMKing620's Avatar
SMKing620 SMKing620 is offline
SMKing620 is starting off with a positive reputation.
So it turns out that my 1, 7, and 8 ignition coils are bad and causing my engine to misfire. I purchased the 3 new coils and want to install them but am a little confused as to what to do with the fuel rail. Am I going to need to depressurize the system and take the whole thing off or is there something I'm missing that will make it easier to pull the coils out and put the new ones in? I'm not too experienced with repairs and would really appreciate any info anyone can give me
Old 02-24-2013, 09:17 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
What year? Should just be able to unbolt the old coil and pull it out. Haven't looked real close on my 3V to know if the fuel rail is that far in the way. I know on the 2V's it isn't.
Old 02-24-2013, 09:56 PM
Ducky F150 Ducky F150 is offline
Ducky F150 is starting off with a positive reputation.
ive talked to a mechanic about that before he said if you take your time you can get them off without pulling the fuel rail
Old 02-25-2013, 05:11 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
#1 should be very easy, #8 the most tricky but even then it doesn't typically require removal of the fuel rail. Using 1/4" drive ratchets & extensions helps considerably.
Take your time, don't let that mess of plusmbing and wiring overwhelm you---it really is just a matter of persistence and careful proceeding.
Check your plug torque when replacing the COP's, don't forget the dielectric grease in the boots and harness connectors too.
Hopefully you have Motorcraft COP's and not a cheap aftermarket brand?
Old 02-25-2013, 12:24 PM
SMKing620's Avatar
It's a '99 4WD Supercab. Yeah I think I should be fine with 1. It's just pulling the heater hose and other wires out of the way to get back to the 7 and 8 coils. The ratchet extension sounds like it'll be necessary. I assume I'll just have to give the coil a good bend to sneak it under the fuel rail. Thanks for the advice guys and if anyone else has some other tips/tricks please let me know.
Ignition Coil Mount??? PintoGuy 1968-2013 Full Size Vans 13 05-25-2015 06:48 PM
Put truck back together, now engine code p0351 mfp4073 Ranger & B-Series 3 06-17-2014 02:38 PM
If you had a dead ignition coil...what are the symptoms? Tonto Kowalski 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 09-07-2013 04:56 PM
Suprise suprise 2005 escape ignition coil problem apalo187 Escape & Escape Hybrid 3 05-05-2010 08:56 AM
Ignition coil. Both wires hot? Thornido Ford Inline Six, 200, 250, 4.9L / 300 5 08-25-2008 01:51 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
