2003 Escape Misfire After Repairs-Please Help - Ford Truck Enthusiasts Forums
Old 02-24-2013, 06:32 PM
MoInSTL MoInSTL is offline
MoInSTL is starting off with a positive reputation.
Unhappy 2003 Escape Misfire After Repairs-Please Help
When extremely foggy outside or after running it through a car wash check engine light comes on and is misfiring. It was very foggy and misty and could not get it to start and had it towed to mechanic. First they said the fuel pump was very low pressure and it was replaced as well as fuel filter. When I went to drive it home I didn't even make off off the parking lot. It acted like it was going to die.
So then they replaced OE replacement wires (coil on plug boots), all 6 Morotcraft spark plugs and plenum gasket. Work done on 1/29/13. Have 54,000 miles on it had original plugs and fuel filter. I know, not good. But I do have the oil changed regularly.
After I got it back it seemed to still run a little rough and slight hesitation on freeway acceleration. Seems to "catch" and then accelerates normally. But that's not the main issue.
Ran it through the car wash a few days later and kept engine running and no problems. Ran it through this afternoon and again kept engine running. This time something got wet and it it sputtered a lot. Acted like it would die at stop lights. Went a few blocks and parked it. Was gone about 10 minutes. When I started it up the check engine light came on and it was obviously misfiring and drove it straight home.
The job notes are:
Running extremely rough after fuel pump replacement
Cylinder/plugwell #5 had oil in it;rear
plugwells had condensation
Original owner, 2003 Ford Escape XLT, 3.0, 54k miles.
Please help. I have already spent a small fortune on these repairs and rental car. Will have it towed back to shop and have them diagnose whatever code it is on their equipment. I am a female and I don't feel comfortable doing much work on it aside from changing the air filter and don't have the tools regardless. I just don't want to be taken advantage of and the expense of replacing Part A, doesn't work so replace with Part B, etc.
After googling, it seems they probably should have replaced the valve cover gasket? Any ideas? What can get wet to cause this? Or moisture from heavy fog?
Edit: Temperature on the mid-40s and let it sit for several hours in the driveway. Just started it and check engine light still on and misfiring
04 4.6 rough idle/ acceleration RyanSta80 2004 - 2008 F150 0 09-09-2015 02:38 PM
Cylinder #4 and #5 misfire priorityautorepair Escape & Escape Hybrid 2 12-15-2014 07:51 AM
2003 6.0 revs up by its self sms2323 6.0L Power Stroke Diesel 13 08-24-2014 06:42 AM
mysterious misfire Starrfan Escape & Escape Hybrid 8 12-02-2013 07:54 AM
04 f150 4.6 running rough and lean has me stumped Ironoutlaw2010 2004 - 2008 F150 3 11-18-2013 08:58 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
