460 EFI parts
460 heads
Category: Drivetrain
Price: $10
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): S2000
Item Condition: VA
Engine: Part suitable for gas truck
If you cant see the pic of the Y-pipe, send me a PM with you email and I'll send it that way. The pipes are solid, have the O2 sensor and hanger near the cat end of the pipes.
F3TE heads
Ineed the F3TE heads.are they complete?I need these shipped.Are you willing to crate these heads?I had a head shipped last week and FedEx cracked three rocker towers.they were only in cardboard box.call 860-716-5637 if you like.I also need smog pump air lines and a lifting bracket,the one on the end of the head .I like your engine test stand,nice job!
Crank/water pump pulleys $10 each or $15 per pair
1 New water pump (GMB) - $30
1 New starter motor (NAPA reman) - $30
1 New alternator (NAPA reman) - $30
1 New oil pan - $70
3 cylinder heads: F3TE - $50 each
1 complete short block - $100
1 block disassembled - $50 with crank, pistons, rods
3 complete induction setups – only 1 is still assembled – need a manifold,harness, injectors?
2 air filter boxes with hoses to intake - $20 each
2 cold air snorkels - $20 each
3 sets of exhaust manifolds - $30 per pair
2 flywheels with good ring gears - $20 each
2 radiators – $30 each
3 sets of valve covers - $20 per pair
1 Y-pipe - $20
1 fan with clutch
Other parts:
Pair of F250 XLT fender emblems – normal wearfor age - $10
Pair of F250 Heavy Duty fender emblems – normal wear for age - $10
2 complete sets of front turn signals and side marker lights – 92 to 97 models- $20 per set (set = left and right)
Pair of front coil springs, 97 F250 HD with 7.3 diesel, truck sat up proud, nosag - $50
Front bumper from 97 with black plastic trim – some dings but very presentable- $40
Rear axle from 97 F250, 3.55 with locker, sway bar and new brake pads - $300
Transfer case from 94 F250 that had 460 and ZF5 - $75
Engine run stand - $400 can be seen here:
[/quote]
1 New oil pan - $70
1 Y-pipe - $20
1 fan with clutch
Other parts:
Parts are flying off the shelf! I'm getting alot of requests lately, which is great, so just thought I would update my list. Also, I've sold stuff that's not on the list becasue people asked if I had a "you fill in the blank" and I did. So if you need something not listed, just ask. For example, I have a new MSD coil for the 460 EFI and a lightly used MSD distributor cap with 8mm accell wires.
3 AC/PS pump brackets - $20 each - 1 left
2 Alternator/smog pump brackets - $10 each 2 sold, found a third pending payment
2 AC delete brackets - $25 each - both still available, make offer
Crank/water pump pulleys $10 each or $15 per pair, sold 1 set, 1 set pending payment
1 New water pump (GMB) - $30 - Still available
1 New starter motor (NAPA reman) - $30 Sold
1 New alternator (NAPA reman) - $30 Sold
1 New oil pan - $70 - Still available with new Felpro gasket. This is a steal at this price
3 cylinder heads: F3TE - $50 each All pending payment
1 complete short block - $100 Still available, tight bottom end, thow on carb heads!
1 block disassembled - $50 with crank, pistons, rods Still available
3 complete induction setups – All injectors sold to a rebuilder, still have everything else
2 air filter boxes with hoses to intake - $20 each Still available
2 cold air snorkels - $20 each - still available, fits all F series with 460 or inline 6
3 sets of exhaust manifolds - $30 per pair - all still available
2 flywheels with good ring gears - $20 each both sold
2 radiators – $30 each still available, one has trans cooler, the other does not
3 sets of valve covers - $20 per pair 1 set sold 2 still available
1 Y-pipe - $20 pending payment
1 fan with clutch, still available, found a second. Both are steel not plastic
Other parts:
Pair of F250 XLT fender emblems – normal wearfor age - $10 still available
Pair of F250 Heavy Duty fender emblems – normal wear for age - $10 still available
2 complete sets of front turn signals and side marker lights – 92 to 97 models- $20 per set (set = left and right) all still available. These parts are expensive from Ford!
Pair of front coil springs, 97 F250 HD with 7.3 diesel, truck sat up proud, nosag - $50 Still available
Front bumper from 97 with black plastic trim – some dings but very presentable- $40 Sold
Rear axle from 97 F250, 3.55 with locker, sway bar and new brake pads - $300 Still available, will part out the gear set, etc
Transfer case from 94 F250 that had 460 and ZF5 - $75 Sold
Engine run stand - $400 can be seen here: Still available... you know you want it
You Tube
Other parts:
You Tube
And by the way... did anyone notice in the engine run stand video that I deleted the PS pump and installed a Chevy (dirty word) 1 wire alternator in the AC position? I was planning to swap this engine into a late 50's truck and didn't need PS or AC and I only wanted to use 1 belt with the tensioner for simplicity. Both of these "home made" brackets are also available.
F3TE Heads sold
Money was sent...yes I noticed and I've been doing that for years on 460's plus GM HEI Ignition which is also aweome despite the critics out there. (Duraspark II sucks *** and so does the charging system)>
#29
Hi, Yes I still have the cold air intakes. I tried to PM, but I think becasue your post count is low the feature is not enabled for you yet. Send me your zip and I can get a shipping quote. Email me at: mark.fugazzotto@gmail.com
