Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 02-24-2013, 04:04 PM
manlikesford manlikesford is offline
Garage is empty, add now
manlikesford is starting off with a positive reputation.
8 lug wheels on 1960 f100
I am confused. I have a 1960 f100 with 8 lug wheels. I believe it is a f250 suspension. I thought the frame was also but the Vin #F10J0R52768 matches the title and according to Vin decoder f100 6 cylinder. Did someone put 3/4 ton suspension on a 1/2 ton frame? Also the rear driver has 9 leafs and rear passenger has 8. The front have 7. Trying to figure out what I have. I have the cab, bed, engine, tranny and front clip off. Thanks for any info offered.
  #2 (permalink)
Old 02-24-2013, 04:12 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Sounds like just what you said. ... 3/4 ton axles on a 1/2 ton. Sometimes the two have different frame widths so other factors may be involved. 2wd? Straight front axle? What wheels are on it? I have at least two trucks with different amounts of leafs on opposite sides, but have to admit, I'm the culprit. They have to sit level, so I do what it takes (without spending $)
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #3 (permalink)
Old 03-02-2013, 06:32 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by manlikesford View Post
I am confused, I have a 1960 F100 with 8 lug wheels. I believe it is a F250 suspension. I thought the frame was also but the VIN: F10J0R52768 matches the title.
F10 = F100 / J = 223 1V I-6 / 0 = 1960 / R = San Jose CA Assembly Plant / 52768 = 1960 Numerical Sequence of Assembly, the trucks specific serial number.
No F100 of any year came with 8 lug wheels on a 6.50" bolt circle. Should have 5 lug wheels on a 5.50" bolt circle.
Front springs are the same 1957/60 F100/250 2WD, could have either 6 or 7 leaf spring packs.
Rear springs interchange 1957/67 F100/250 2WD. 1957/64: F100's could have 7 or 9 leaf spring packs, F250's could have 7 or 10 leaf spring packs.
1965/67 F100's could have 5, 6 or 9 leaf spring packs. 1965 F250's could have 7, 10 or 11 leaf spring packs. 1966/67 F250's could have 6 or 8 leaf spring packs.
btw: I was confused...once. 1989: While on vacation in WA, driving on I-5, I see a billboard that says "Do the Puyallup" Wondered what the hell does this mean? Found out later it's the local county fair.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
