03 SD trailer brake controller wiring
Ok so I finally got some time to install my Maxbrake controller. I looked at the video on etrailer.com and my harness was not to the right of the steering column where their video showed.
Here's what I did find, idk if these are factory installed pass throughs or someone blunt cut the plug.
Under the hood
Above the e brake release
Any insight?
Under the hood
Any insight?
The brake control plug is there, it's just very hard to find. Look to the right of the open space under the steering wheel. You'll see a metal frame with a smallish triangle cut out of it. Stick your fingers through the cut out to the rear. You should feel the plug attached to the frame there.
The wires you are seeing are the pass through wires (4 wires under the hood match 4 wires by the parking brake), and the customer access wires (the other wires by the parking brake). None of them have anything to do with the brake controller connector.
eforer
1999 to 2016 Super Duty
07-20-2019 04:52 PM
CruiserClass
06-07-2010 09:41 PM
60RatRod
09-21-2008 07:11 PM
JBrent
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-02-2004 01:57 AM
