How I got my truck to weigh 3980 lbs...
Yes... California and its DMV can suck it... To hell with their weight fees. Commie *******s.
Here are a couple pics if it helps... I did have to cut the exhaust off from the back of the cab to make this work.
Feels really light... I removed about 300lbs or so of stuff. Fortunately this is a one time event.
Haha. Yeah. If I ever try to get it down to 2980 (the scale measures in twenties) (This is the next tier down in weight class) I might try that... Not sure if between the bed and the doors I could get it that low and I don't have much else to remove while keeping it drivable unless I put a 4 banger from a ranger in it to save 500lbs from the 390, np435, and the transfer case. I think that would be going a bit extreme.
Gotta know when to be happy with what I got. This saves me about $55 a year on registration. Going a tier down would only be another $20. It can be done but not really worth the effort. This took all of an hour to tear down and another hour to put back together.
I bought a 89 f350 short wheelbase dually, 351w efi, zf42 5 spd. $450. The body was crap but the rest is good. Once I've changed the cab I'm scaling the cab & chassis with 800lb on it to represent the fuel weight. (front tank is almost full now). Then I'll start weighing things like buddies aluminum rims & tires, my steelies,etc and start taking it from there. I know theres a shorter drive shaft available and that might be the next wheelbase if I know for sure I'm not going to make weight.
that deck had a 7.5'x 11.5' 3/16" plate over 2x6 t&g over 2x3 c channel ribs on 2x6x 12' rails plus the subframe for the hydraulics x 2 pcs and all the outside frame / dress up metal. Thats my project metal now.
flixden
2009 - 2014 F150
27
03-28-2012 09:34 AM
BioHazrdMan
28
12-15-2009 06:35 AM
