Hey guys, I'm restoring a 66 custom cab shortbed. Can anybody tell me where I can purchase rubber grommets that insulate tail lights wires that run through the frame?
I'm restoring a 66 Custom Cab shortbed. Can anybody tell me where I can purchase rubber grommets that insulate tail lights wires that run through the frame?
374311-S .. Grommet-Taillamp Harness / Obsolete
1965/66 F100/250 2WD / GREEN SALES CO. in Cincinnati OH has 76 = 800-543-4959.
As I recall the same grommets were used in the holes above the master cylinder where the RH engine comp't wiring is sometimes routed through. Not all trucks have these grommets used however even when the harness is routed through those holes. Im pretty sure I have a couple of those around... PM for more info.
