Need some help finding parts
Old 02-23-2013, 07:10 PM
tracytruelove's Avatar
tracytruelove
tracytruelove is offline
Hey guys, I'm restoring a 66 custom cab shortbed. Can anybody tell me where I can purchase rubber grommets that insulate tail lights wires that run through the frame?
Old 02-23-2013, 07:33 PM
camperspecial65's Avatar
camperspecial65
camperspecial65 is offline
Those typically arent sold unless with wiring kits...I f you want, PM me or post a visitor message and i can tell you a bit more about them.
- cs65
Old 02-23-2013, 10:55 PM
SuperSabre's Avatar
SuperSabre
SuperSabre is offline
Have you thought about looking in ACE Hardware or your local speed shop?
Old 02-24-2013, 02:32 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by tracytruelove
I'm restoring a 66 Custom Cab shortbed. Can anybody tell me where I can purchase rubber grommets that insulate tail lights wires that run through the frame?
374311-S .. Grommet-Taillamp Harness / Obsolete
1965/66 F100/250 2WD / GREEN SALES CO. in Cincinnati OH has 76 = 800-543-4959.
Old 02-24-2013, 02:16 PM
DKluke's Avatar
DKluke
DKluke is offline
Go to Lowes, Home Depot or Tractor Supply. Between those 3 you should be able to find all the nuts, bolts or rubber grommets you need.
Old 02-24-2013, 04:49 PM
jowilker's Avatar
jowilker
jowilker is offline
Check with Rick at Carolina Classics, he has had them in the past.
John
Old 02-24-2013, 05:38 PM
camperspecial65
As I recall the same grommets were used in the holes above the master cylinder where the RH engine comp't wiring is sometimes routed through. Not all trucks have these grommets used however even when the harness is routed through those holes. Im pretty sure I have a couple of those around... PM for more info.
- cs65
Old 02-24-2013, 06:28 PM
old broke prospector's Avatar
old broke prospector is offline
Check with your local paint and body shops, they may have a few extra on hand.
Old 02-25-2013, 05:23 AM
markzieglerinsd's Avatar
markzieglerinsd
markzieglerinsd is offline
LMC has them in their catalog.LMC part number 40-1200 on page 139.
Mark
gangstakr
03-14-2015 01:28 PM
chaser1602
13
08-24-2014 07:54 AM
1964Goat
08-09-2014 12:46 PM
bones93
03-09-2012 05:16 PM
fordparts429
07-14-2011 05:33 PM
Quick Reply: Need some help finding parts
