I Need Help...
i BELIEVE that's the PCM power relay, is it not? 4 contacts, two large 2 small? Some variants have 2 large, 3 small. There are about 1 billion revisions of that relay. The part is 12A646. E7FZ12A646A is probably what yours is. Its available as:
Most replacements do not have the offsets/keying, but will work as long as you double check pin alignment before installing. Standard Motor Products sells a compatible part. Its about 9-15 bucks online. You can pick one up from autozone and other parts stores.
Green should be a fuel pump relay. Alternates below:
BWD AUTOMOTIVE R3080
KEMPARTS AR214
NAPA AR149
NAPA AR149SB
STANDARD MOTOR PRODUCTS RY111
WELLS 19841
KEMPARTS AR214
NAPA AR149
NAPA AR149SB
WELLS 19841
Code:
APN(s): 83458021, D8PZ14N135AA, DY308, DY343, DY368, DY408, E1AB12A646BA, E1AZ12A646A, E1VB12A646AA, E1VF12A646AA, E1VY12A646A, E2VB12A646AA, E2VY12A646A, E35F12A646A1A, E35F12A646A2A, E35F12A646B1A, E35F12A646B2A, E35F12A646BA, E3AF12A646A1A, E3AF12A646A2A, E3AF12A646AA, E3AF12A646B1A, E3AF12A646B2A, E3AF12A646BA, E3AZ12A646A, E3EF12A646A1A, E3EF12A646A2A, E3EF12A646B1A, E3EF12A646B2A, E3TF12A646BA, E3UF12A646A1A, E3UF12A646A2A, E3UF12A646B1A, E3UF12A646B2A, E3UF12A646BA, E3VF12A646BA, E43F12A646B1A, E43F12A646B2A, E43F12A646BA, E43Z12A646B, E4LB9C392CA, E4LB9C392DA, E4LY9C392C, E6AZ9C392D, E7AZ9C392A, E7TZ9C392B, E9TZ9C392C, F1TZ9C392A, F8PZ14N135BA, F8PZ14N135CA
Code:
APN(s): 19911, 1R1125, 1R1206, 88922679, 88922721, 88922813, 88922865, E1AB14A093AA, E1AB14A656AA, E1AZ14677A, E1DB14A093BA, E1EB14A641BA, E1EB8B658AA, E1EB8C616AA, E1UB13A435AA, E1VB13A435AA, E1VB13A435BA, E1VB13A435CA, E1VB14512AA, E1VB14A093AA, E1VB9345AA, E1VB9345BA, E1VB9345DA, E1VY13A025B, E1VY13A025D, E1VY13A435A, E1VZ9345A, E1VZ9345B, E27B13A435AA, E2BB14A093AA, E2EB8C616BA, E2EB9345AA, E2VB13A025B1A, E2VB13A025BA, E2VB9345AA, E35B13B401AA, E3AB13A025AA, E3AB13A025BA, E3AB14512BA, E3AB14A656AA, E3AB14A672B1, E3AZ13A025A, E3AZ13A025B, E3AZ13A025C, E3DB13B401AA, E3EB11433A1A, E3EB11433A2A, E3EB11433AA, E3EB12B598AB, E3EB9345B1A, E3EB9345B2A, E3EB9345B3A, E3EB9345C1A, E3EB9345C2A, E3EB9345C3A, E3EB9345CA, E3EB9345DA, E3EB9345EA, E3FZ9345C, E3FZ9345D, E3FZ9345E, E3SB11433AA, E3SZ11333A, E3TB13A025A1A, E3TB13A025AA, E3TB13A025BA, E3TB9345A1A, E3TB9345A2A, E3TB9345AA, E3TB9C392AA, E3TB9C392BA, E3TB9C392CA, E3TB9C392DA, E3TZ9345A, E3UB13A025AA, E3UZ13A025A, E3UZ13A025AA, E3VB11433A1A, E3VB11433AA, E3VB13A025BA, E3VB13A435A1, E3VB13A435A1A, E3VB13A435AA, E43B11433A1A, E43B11433AA, E43Z11433A, E45B17D736AA, E4DB13B401AA, E4EB7G080AA, E4LB11433AA, E4LB9C392AA, E4LY11433A, E4SB13B401AA, E4ZB9C392AA, E4ZZ9C392A, E53B11433AA, E53B9C392AA, E59B13B401AA, E5DB11433AA, E5EB13A025A1A, E5EB13A025AA, E5EB14A093AA, E5LB2C222AA, E5LB9C392AA, E5LB9C392CA, E5SB11433AA, E5VB11433AA, E5VB14A656AA, E5ZB11433AA, E63B11433AA, E63B13A025AA, E6AB12B563AA, E6AB2C222AA, E6AB9C392BA, E6DB13C117AA, E6EB11A159AA, E6EB9345AA, E6FZ9345A, E6LB9345AA, E6LB9C392AA, E6TB13A025AA, E6TZ13A025A, E7TB9C392AA, E8AB13A025A1A, E8AB13A025A2A, E8AB13A025AA, E9EB2C013AA, E9UZ9C392A, F19B9345AA, F19Z9345A, F1SZ9345A, F1UB9C392A1A, F1UZ9345A, F8PZ14N135AA
Most replacements do not have the offsets/keying, but will work as long as you double check pin alignment before installing. Standard Motor Products sells a compatible part as RY71. Its about 9-15 bucks online. You can pick one up from autozone and other parts stores.
Code:
Code:
mmmm okay let me show picture of relay connecter used to plug on brown relay..
Here's something I've found very useful, even keep it on my computer:
http://www.fordtechservice.dealercon...torcatalog.pdf
Local Ford dealer turned me onto this---the printed versions are now collectible items on FleaBay!
Code:
Code:
Does E6FZ12A646B work same as E7FZ-12A646-A???
It appears to be functionally the same. The number you keep giving is a drawing reference number. They change all the freaking time (every year in fact.)
The relay can be replace by any generic relay. A relay that would fit the factory connector is available from auto-zone, here:
Duralast/Relay - ECM Wiring (19840) | AutoZone.com
It is listed as the PCM relay for an 89 E250.
but DY-408 is replaced to DY-865 F8PZ14N135BA
DY408 ~ Quality parts from OEHQ.com
Part 1 -Ford EEC Power Relay Test.
so, i just curious why DY-408 is cheap than dy-865?
jniolon
16
04-05-2018 01:43 AM
