Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 02-23-2013, 02:23 PM
The Eddie's Avatar
The Eddie The Eddie is offline
Garage is empty, add now
The Eddie is starting off with a positive reputation.
Fuel Tank Gasket Material Suggestions?
When I went to Biodiesel, I swapped out the OEM steel tanks with plastic replacement tanks; and it did not even occur to me upgrade the brand-new gasket used in the sensor and fuel piping flange.
Well, they're gushing mass quantities at fill up time now. I thinks these gaskets were probably rubber--the tanks were made for gasoline and petrodiesel.
Anybody have any suggestions for easily obtainable material? I'm thinkin' a roll of material--I need to cut 3 of these-they're circular, 4-5 inches OD, flat, minimum of 1/8" thick--best of my recollection.
Eddie
  #2 (permalink)
Old 02-23-2013, 02:41 PM
binuya's Avatar
binuya binuya is offline
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
Something I have done is used silicone sheet to make gaskets. You might be able to find it cheaper somewhere else, but if you go to the cookware section in a Target or Walmart, they have silicone baking pans, cookie sheets, etc. If I remember right, I found a brownie pan on sale for $6-$7. The ones I have found are about 1/8" thick, easy to cut, and better yet, easy to find.
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
  #3 (permalink)
Old 02-26-2013, 04:25 PM
The Eddie's Avatar
Good On Ya!
Thanks! Gives me something to actually do, next time I hafta take Herself shopping.
eddiE
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
