2006 Power Steering Whine/Howl
NOOB Alert
Just picked up a 2006 S-Crew Triton that needs a little TLC. The thing that is bugging me the most is the power steering pump whine/howl. I know this is a typical symptom of the older Fords, but has anyone had luck with any of the replacement brands to eliminate the whine? I tried the friction modifier, and if anything, it got worse.
OK, I would do a flush and fill before buying a new ps pump. spend the extra $ and buy the synthetic oil and see if the whine goes away. Its a lot cheaper fix than a new pump. If that isn't the fix, then replace.
Also, the friction modifier goes in the differential oil not the power steering oil.that's probably why it got worse
I believe this pump is beyond fixing it with a flush. It sounds like a late 80s Ford. The fluid in it is nice and pink. I don't really want to throw a $30 fluid change at a $60 pump for it not to fix the issue, then have to buy the pump and flush again, putting that new fluid in the waste pan.
Jeff-150
03-16-2007 08:25 AM
jarrod b
10-12-2006 09:45 PM
