Stop changing your oil! A discussion.
I read that article some time ago. That info coupled with all the oil analysis I have seen reported on this site convinced me to go to 10k intervals. I am at the end of my first 10k interval in the next month, and I will be sending a sample off for my first analysis on the X If it weren't for the leaky turbo pedestal, I wouldn't have even needed to add oil on this cycle. Oh well, that pedestal's days are numbered...EBPV and actuator are getting deleted at the end of the month!
A guy that I recently helped out, with some low power issues, performed the first oil change on this 03 at 147,000 miles fresh oil did not change sound or power. Needless to say I was amazed on an HEUI injected motor.
Now this was not with oil analysis, or any special filtering or treatment this was sheer neglect...
I said the same Neal...
And I mistakenly mentioned the year, it was an '04.
I had told him I would not try to diagnose his low power issue without at a minimum of the oil and filter changes with genuine motorcraft parts. Even though his recent issue pointed towards a sticking turbo and EGR valve. I was surprised though that after cleaning the turbo and EGR the "power" that he had was as good as he and I thought it should be, and the oil change didn't appear to "help" any with his low power issue...Makes me wonder how long he would have neglected that truck if he didn't have a larger issue.
Many of us, including myself, are guilty of going beyond the recommended oil change intervals. While most won't notice any problems, it doesn't mean that there isn't an issue developing. These recommendations by the manufacturers are there to promote the longest life possible out of these engines. So while extending your oil change intervals beyond the OEM recommendations might not show immediate damage or problems, doing so continuously could eventually catch up to you in the long run.
I would never once consider going any interval recommended by an oil company. Those recommendations factor in only the oil life on the average engine, and does not reflect the specific needs of certain motors, such as the 7.3L PSD that utilize a high pressure oil-driven injection system.
Furthermore, an oil analysis may help or hurt, depending on how the end user interprets and understands the data. What information is reflected in an oil analysis is the typical values for that particular oil group, but does not necessarily reflect what is "normal" for a specific engine type. In other words, an oil analysis does not necessarily reflect what are the acceptable values by the engine manufacturer. So while an analysis may show the oil as having more life up to "X" miles remaining, it doesn't always mean that those are acceptable values for a specific engine or recommended by the OEM manufacturer.
As for filtration bypass systems and other oil system modifications, those should be treated as precautionary safeguards rather than systems to extend oil change intervals.
With that said, I tend to change my oil every 5,000 miles, even though my truck endures "severe" rather than "normal" driving conditions most of the time. Given the design of the engine and the utilization of the high pressure oil pump, I personally would not endorse extended oil changes on these engines. For most other engines it wouldn't be as much of a problem, but engine oil in the 7.3L's endures much more punishment thanks to the HPOP. Even the most robust oils will shear and break down.
