Master cylinder question with disk brakes
I have a 67 f100 that I recently converted to disk brakes from a dent side. Used dual piston.
At the moment I'm using the stock proportioning valve and master cylinder.
As of today, my MC went out and I'm gonna pick up a new one from the parts store tomorrow
What should I use? Stock 67 style for drums or a late 70s style for dual piston calipers?
use a disc brake MC.
without going into a lot of detail: drum MCs and disc MCs aren't the same internally.
Master Power Brakes - Reference/FAQs: Master Cylinders
really, you should have switched MCs when you put the discs on.
If you are going to run disc-drum setup, do it right with all the correct parts. You need the porp. valve from the donor truck, the discs & drums are different aminals, with different requirements.
Everything needs to be from the correct set. BUY A DONOR GET ALL THE CORRECT PARTS GUYS!
John
It has 3/4 ton stuff on now, 8 lug.
I just finished the truck the other day
I have the new pro. valve too just haven't made new lines to put it in, and everyone said I don't absolutely need it, even though I'm going to and I'm aware im not getting full potential out of the disks
And I wasn't aware of the different MCs, truck stopped great the past few days but just randomly went out.
But looks like I'll order one for a 73 f250 with dual piston calipers.
it makes it hard to bleed the rear brakes? the original one is on and brakes worked fine for a few days untill the MC went out.
I'm not mixing parts. I have a 8 lug dana 60 rear. Truck has full 3/4 ton suspension and drivetrain. And just picked up and new MC and putting the prop valve on.
I'm sorry, what has been talked about does not apply to a F100.
John
A drum/drum system does not have a proportioning valve. It has a distribution block, which basically just distributes fluid to the brakes on one side of the system or the other.
A disc/drum system has a proportioning valve. A proportioning valve will alter the fluid pressure to the front and back, as they have different pressure requirements.
You CAN use a distribution block on a disc/drum system and get away with it..... until you have to make a panic stop. Then you will wish you had the proportioning valve.
Bottom line: Never use a distribution block on a disc/drum system!
whackit
11-29-2012 04:42 AM
55 f350
16
04-30-2009 01:49 PM
