97 f150 lariat - Ford Truck Enthusiasts Forums
97 f150 lariat
Old 02-22-2013, 10:19 PM
Pequeaford Pequeaford is offline
Pequeaford is starting off with a positive reputation.
97 f150 lariat
I've been driving my dads truck. I now have a problem with the wipers. The low speeds don't work but the highest two notches do. I still have windshield washers. I'm lost and could use some help on where to look. Any help wouldbe appreciated.
Thanks
Jesse
Old 02-23-2013, 07:51 AM
Spotty Spotty is offline
Spotty is gaining momentum as a positive member of FTE.
My guess would be the switch. Sometimes they call that a "multi function switch" because it also controls the turn signals and your 4-ways. It is easy to change, IIRC just pop out the ignition key switch, take off the upper and lower shrouds and it's right there. Pull the negative cable b-4 you start and wait 5 minutes....you are in air bag territory. New ones are in the $45-50 range and salvage yard around $15...(in my area). Good Luck.
Old 02-23-2013, 08:01 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Spot-on advice!
Somewhere around here is a procedure to take the switch apart and clean it. Usually fixes the problem with the interval wipers.
Old 02-23-2013, 10:38 AM
Club Wagon Club Wagon is offline
Club Wagon is gaining momentum as a positive member of FTE.
Intermittent wipers went squiffy on my '98 XLT. All the intermittent positions usually gave one sweep of the wipers. The low constant speed position gave 1 intermittent speed & the high constant position gave constant wiper action.
The GEM module was suspected. This Black Box is deeply buried behind dash left knee panel, a PITA to R&R.
Was going to try to find replacement at U-Pull junkyard, but just the probing, jiggling & attempt to check if wires going to GEM were snug, in place, restored proper functioning.
Wipers have never hiccuped again.
Old 02-23-2013, 06:03 PM
Thanks. Went to lunch from work today and they worked off and on. Them coming home from work they were fine. Could to be that the switch needs cleaned of dust. This truck sits alot.
Old 02-23-2013, 11:29 PM
Suspect if was as EZ as "the switch needs cleaned of dust" you'd be able to just wiggle the switch & get it to work. Especially if you have intermittent "worked off and on" issue.
My TIP about "jiggling" the wires going to the GEM apparently restored a loose connection.
My wiper problem was intermittent, as in not all the time. Sometimes the delay positions worked fine, for weeks. Then there were no delay speeds. Some times on same trip it "worked off and on".
Since I "jiggled" the GEM wires it never happened again. That's like 2 years ago.
Old 03-06-2013, 08:17 AM
Ok I didn't do a thing and the wipers work now. Thank y'all for your help
Bed mounted spare tire StumpPullerF1 1987 - 1996 F150 & Larger F-Series Trucks 5 01-30-2011 12:36 AM
What year is Uncle Jesse's Truck? wyazel1 1973 - 1979 F-100 & Larger F-Series Trucks 37 08-22-2008 07:16 PM
Let's welcome Jesse back! msgtg West Virginia Chapter 11 01-23-2008 11:57 PM
Anubody remember the name of Uncle Jesse's truck? thunderb 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-09-2006 01:58 PM
Manifold testing jesse 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-05-1999 06:13 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
