V-10 dyno results
V-10 dyno results
I just got back from the dyno and thought ya'll might like to know the results. My truck is a 2002 F250 SD V-10 w/3.73 gears w 285/75/16 tires. I've added Diablo chip, Airaid cold air filter/w zoodad mod? (hole in the front grill), and flowmaster 70 muffler.
With the chip off I pulled 235.7 hp @ 4000 rpm - 4600 rpm & 308.6 tq @ 3200 rpm - 4000 rpm
With the chip on I pulled 247.7 hp @ 4000 rpm with a peak at 4400 rpm & 335.1 tq @ 3200 rpm - 4000 rpm
Overall with the chip I gained 12Hp & 26.5 TQ. I did not dyno stock so I don't have that to compare it with. The torque is lower than I would have guessed, but that could be due to the open airfilter system. I saw this with a car I once had and dyno'ed. With an open filter the torque was lower than stock.
The chip improved the Hp & TQ at all rpm's. From 4000-4300 rpm's it was the same as stock and from 4400 Rpm's it jumped way above stock(like I ever drive at that rpm much)
The owner of the dyno said these #'s are just a hair low due to the taller tires. The dyno is a little off with tires above 30 inches truck or car. The only other FORD V-10 he had Dyno'ed was in a van, it only pulled 180 HP. I've also dyno'ed my SS here and the #'s were almost as expected in relation to 1/4 times, so the #'s for this truck are pretty true.
I plan on adding headers in the near future along with a new TB & TB spacer. I'll dyno it at that time along with the chip being set up for it. We'll see what I end up with then as I'm sure that will be enough YEA RIGHT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Macrobb
21
03-14-2021 09:49 AM
RacinNdrummin
69
07-07-2016 07:42 PM
kenneBF250V10
Modular V10 (6.8l)
22
08-04-2005 06:01 AM
