2006 6.0 Glow plug system
Hi to all, I have a 2006 F350 dulley with a 6.0. A while back i got a code for #8 glow plug and had the warrenty fix it. Well the warrenty is over now and I want to fix my newest problem.
I have a code P0671 cylinder 1 glow plug circuit and the engine light is on. So I would like to replace all the glow plugs and harneses. Could someone help me with the part numbers for what I need to fix this. I figure I will replace all and not have any problems for a while. I have just under 88K on the 6.0. Thank you in advance for any help offered.
Willi
Willi
2006 FORD F-350 SUPER DUTY Parts - Tousley Ford Parts Depot
You may need a special tool to remove the harness from the glow plug.. Not too sure tho.
Thanks for the reply. I will check them out
Willi
Okay, I'll bite. I just tried those links and they didn't look right, so here are the part numbers for your 2006:
4C2Z-12A690-AB (Glow plug harness right side)
5C3Z-12A690-A (Glow plug harness left side)
ZD-13 (Glow plug)
Ditto on Moe's comment regarding the glow plug harness removal tool. It is almost as useless as TiT$ on a bull.
ZD-13 (Glow plug)
ZD-13 (Glow plug)
ZD-13 (Glow plug)
I checked out the link and they did look like motorcraft glow plugs. I did find the same ZD-13 so thats cool. I will have to look for the left and right side. Thanks for the reply
Willi
tayous1
03-30-2012 08:04 PM
