1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
'62 or '63 pickup?
Old 10-25-2007, 10:19 PM
Dan1988's Avatar
Dan1988
Dan1988 is offline
Question '62 or '63 pickup?
Hello all,
I'm trying to decide between a 1962 unibody with a Chevy 305 and TH350 or a 1963 with original 250 and 3 speed. Wha's the differences between these 2 models? Is it better to go with one over the other? Any suggestions/advice is welcome.
Thanks
Dan1988
Old 10-26-2007, 02:36 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Dan1988
Hello all, I'm trying to decide between a 1962 unibody with a Chevy 305 and TH350 or a 1963 with original 250 and 3 speed. Wha's the differences between these 2 models? Is it better to go with one over the other? Any suggestions/advice is welcome.Thanks,Dan1988
Welcome to FTE
The 1962/63 Ford Uni-bodied pickups are nearly identical. the only real difference is the grille. The engines used were either a 223 or 262 I-6, or the 292 V8. There's no such thing as a 250 engine for pickups.
Chevy engines in Fords are frowned upon around here.
Old 03-08-2013, 05:22 AM
ponderbuzzard's Avatar
ponderbuzzard
ponderbuzzard is offline
62 or 63 F100 Unibody decision
Believe the body, engine, and chassis condition of trucks and the asking prices would be major consideration as to preference, along with what you intend to use the truck for. As example air conditioning might be a possible advantage of the Chevy engine, if you want AC. There is much to consider and the measurement scale is not clearly defined. You could remove the Chevy engine, transmission from the one truck and sell it for perhaps enough to buy a more appropriate engine, transmission, and in the process take on a lot of wrenching time.
Is performance an issue or is this a run to the dump or Box Store truck?
Five people, five opinions.
BigDan1
13
07-19-2015 03:34 PM
BigDan1
19
04-02-2015 06:24 AM
DNA_32746
04-01-2015 11:02 PM
mcanik
11-18-2003 07:06 PM
Dan G
15
01-28-2002 01:32 PM
Quick Reply: '62 or '63 pickup?
