Pinion angle and shocks
I have my 58 lowered. I notched both the front and the rear. And I put the axles on top of the springs. Can someone help me with the angle the rear end needs to be set? I am ready to weld the new preaches to the rear end. Also, I need new shocks. How do I measure the lenght? Mount to mount with the truck on the ground????
Thanks
Scott
Thanks
Scott
on
you need to measure the angle of the rear of the transmission to determine what angle the pinion needs to be set at. the two faces need to be parallel to each other at ride height. also you want the rear end to point down about 2 - 3 degs from above angle so when under power they are parallel.
do a google search on pinion angle setup as there are quite a few articles on this subject and also on shock measurements.
rgds
Mike
rgds
Mike
Scott; Here is a link to John Niolons web site that discribes drive line phasing.
DRIVE LINE PHASING
Good luck in your quest!
We all like pictures, please share your project.
DRIVE LINE PHASING
dsrtjeeper
30
02-08-2013 08:44 PM
ernietorrado
01-11-2010 05:09 PM
sully13
12-18-2007 02:29 PM
RUSTY50F1
07-28-2007 06:30 PM
