1949 ford engine firing issues
Old 12-10-2012, 02:21 PM
1949badass's Avatar
1949badass
1949badass is offline
when i step on the gas, the engine begins to cut out and lose power, as if its missing while firing. ive checked the firing order ,which is correct. any ideas?
Old 12-13-2012, 08:20 PM
geomechs's Avatar
geomechs
geomechs is offline
Something that comes to mind is bad coil, coil not wired correctly, or you might not be having a problem that isn't related to the ignition system at all. For example my '47 started and idled perfectly but wouldn't rev up at all. It turned out that my accelerator plunger had folded a corner over and wasn't working. Fixed that and everything worked fine.
Old 12-15-2012, 06:31 PM
1949badass's Avatar
1949badass
well the coil is brand new. as i listen to it more, it sounds like its missing even on idle. I was told it could possibly be something with the carburetor, where i need to disassemble it and unplug some lines in. If this is the possible case, any idea where i would find some schematics to follow along with?
Old 12-15-2012, 10:12 PM
19fifty4's Avatar
19fifty4
19fifty4 is offline
Have you rebuilt the carb? Also, just because the coil is new doesn't mean you might not have gotten a bad one.
Old 12-16-2012, 07:14 AM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
Is this problem an all of a sudden thing or has it an old one that you're working on .Without hearing it run I would suggest accelerator pump or vacuum advance .
Old 03-12-2014, 10:49 PM
speedwrench72's Avatar
speedwrench72
speedwrench72 is offline
put a dwel meter on it and tape it to the windshield so you can see it and go for a drive, if the dwel meter jumps around when it is missing the distbutor needs rebuilt, cuz of to much play, will make for the points not to open consistently under load.
Tigerpride35
1999 to 2016 Super Duty
11-24-2017 09:56 PM
dixiefried
06-03-2006 03:14 AM
jb1234
05-20-2006 10:17 PM
rsat61
3.8 & 4.2L V6
08-14-2004 06:19 PM
GarySS
06-23-2004 03:38 PM
Quick Reply: 1949 ford engine firing issues
