Metal shavings on IPR screen? - Ford Truck Enthusiasts Forums
Old 02-20-2013, 09:57 PM
Piolet's Avatar
Piolet Piolet is offline
Piolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to behold
My IPR screen was very slightly pushed in and had a few small metal shavings on it. Screen was not torn.
According to the 6.0 Bible, the HPOP and IPR comes after the oil filter, and the engine lubrication and LPOP are before the oil filter.
Are they likely to be the result of the HPOP on the way out?
Truck is getting a new HPOP installed because the old one was causing a multi-crank start when parked nose up and no problems when parked nose down so leaking shaft seal was suspected.
I hope the shavings are just a mark of the HPOP problem and not a sign of a larger 2nd problem.
Any thoughts or comments from anyone?
Edit: screen under oil cooler was not torn so I guess I'm ok now that I think about it.
Oiling system upgrades/maintenance the_auto_tech 6.0L Power Stroke Diesel 10 01-20-2015 10:47 AM
2005 6.0 no start when hot Bill Pittman 6.0L Power Stroke Diesel 10 01-13-2015 08:03 AM
IPR screen - Newer motor. what would you do. brown89ford 6.0L Power Stroke Diesel 8 01-08-2015 04:38 PM
2004 F250 HPOP Screen, Metal Contamination 1994F2507.3L 6.0L Power Stroke Diesel 1 08-16-2014 11:33 PM
Metal shavings in IPR valve FiznUKa 1999 - 2003 7.3L Power Stroke Diesel 25 06-08-2014 08:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
