6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Cooling system flush questions
Old 01-01-2013, 07:45 PM
TEMiller's Avatar
TEMiller
TEMiller is offline
I got some test strips to test coolant and everything seems in order except nitrates. It looks like the nitrates are right around the 300 level. Can I just drain and refill the system or should I run the flush fluid through it? Why do we have to be concerned about the nitrate level, what purpose do they serve?
Do I have to be extra concerned about bleeding air out of the system while refilling?
Old 01-01-2013, 08:45 PM
RM2738's Avatar
RM2738
RM2738 is offline
You can add Motorcraft's Coolant Additive ONE time per flush interval to rejuvenate the Nitrites.
If you've already done that or are unsure of the history, I'd do a nice thorough flush since coolant systems seem to be the death of these trucks. You have to be meticulous and thorough. Drain, flush with hose, fill with Distilled, idle, drain, more Distilled, drain, new coolant/Distilled mix, idle, top off, drive a few miles, top off. Keep an eye on it for the next few dozen miles and top off as necessary.
Or... If you can find a vacuum filler, that would be ideal.
Old 01-01-2013, 08:48 PM
RM2738's Avatar
RM2738
RM2738 is offline
Forgot to add the use of Motorcrafts Coolant Flush additive wouldn't be a bad idea as well.
Old 01-03-2013, 06:00 PM
wp6529's Avatar
wp6529
wp6529 is offline
Old 01-08-2013, 02:41 PM
Mystic_Cobra's Avatar
Mystic_Cobra
Mystic_Cobra is offline
Originally Posted by wp6529
Thanks for the link. Would have been nice if you'd added a comment of some kind so users don't wonder if the link is a phishing scam or something.
Has anyone actually used this procedure?
In the document, it states...
"...commercial vehicles with auxiliary heaters..."?
What is this aux heater?
"remove the starter"?
WTF?
Old 01-08-2013, 03:25 PM
wp6529's Avatar
wp6529
wp6529 is offline
I think the aux heater they refer to would be something like the one in the back of the shuttle bus conversions you see used at hotels and airports. Just more total system volume I think.
I've not personally used the procedure, I've had my dealer do it after discussing it. With all that fluid to drain and dispose it's nice to let someone in a "real" shop deal with it.
The procedure for a contaminated system is even worse, they start with a run of Simple Green Pro HD solution, then like two more clear water runs to clear the cleaner, and then go into this VC-9 flush procedure to finish it off.
If you do it yourself, you can use the SEIC function to do the fast idle instead of needing a scan tool. Either way it's a lot of distilled or RO filtered water and a lot of coolant and flush solution to dispose of.
Old 01-08-2013, 08:56 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
If you're still not done with the flush yet you can go on line to" power stroke help" and get his. It's on a you tube. it's not quite as involved as the one in the manual (he doesn't drain the block) but is very thorough. I did mine that way and added a sinister coolant filter a couple months back and everything seems to be OK. I tell ya, that last flush was clean enough to drink.
Old 03-06-2013, 05:00 PM
Mystic_Cobra
coolant mix is 50/50 with distilled in these, right?
dwh039
6.2L V8
01-28-2016 09:12 AM
Cpap
6.7L Power Stroke Diesel
12-13-2015 09:14 AM
thinksnow
2004 - 2008 F150
05-23-2013 10:03 AM
jgilrfr
13
08-09-2011 11:54 AM
mh5500
06-05-2010 09:14 AM
Quick Reply: Cooling system flush questions
