When dropping the rear tank on my 1993 f150 do I need special tools to remove the fuel lines from the pump. Also , with the rear tank removed will I be able to run on the front tank with no problems.
Thanks
You'll be able to run on the front tank if you plug the lines to the rear tank. The front & rear tank lines are just connected with "Tees". Switching is done with valves in the fuel delivery modules...
