I have my 1956 ford f100
#271
#272
Los guardabarros los he puesto lo mas delante posible , parece que no tienen mucho margen debido al tornillo superior que las une a la cabina,
sobre el capo lo intento colocar lo mas atrás posible pero aun no se ajusta en las esquinas delanteras( pondré fotos) y me preguntaba si las barras que trae bajo el capó sirven para ajustar? .
En la parte delantera del lado del condutor el capo me queda alto y no se el motivo y en la parte del acompañante sobre sale unos 5mm .
Gracias.
#274
Hi Guys,
Capelo is having some challenges getting his hood adjusted just right.
"The fenders are pushed to the front as much as is possible but there isn't much room owing to the screw above that is hitting the cab. My intent is to move it further back but I can't adjust it in the corners (see fotos). My question is - Are the bars/poles below the Hood for adjusting?
In the Front on the driver's side the screw or bolt remains high
& I don't know how to move that part - It's 5mm off. "
That's the best I can do translating from afar. Basically Capelo is having trouble getting his hood aligned & he doesn't know the correct process.
Ben in Austin
1950 F1
Gracias Ben , necesito un poco de ayuda para comunicarme ya que no se las expresiones correctas.
Gracias.
Ben in Austin
1950 F1
Gracias.
#277
#278
#282
#284
